Temp stuck at 260 - any ideas?
Old Jun 30, 2014 | 10:30 AM
SLO VETTE's Avatar
SLO VETTE
Default Temp stuck at 260 - any ideas?
Car's running fine, plenty of coolant, never leaked, etc.
I haven't driven car in many months, went out for a spin and it's pegged at 260.
Got any ideas? Thermostat issue, and if so, got a specific part or part # that would be a good first look?
Many thanks.
Old Jun 30, 2014 | 10:38 AM
3boystoys's Avatar
3boystoys
How fast did it get up to 260? Did you feel the hoses to see if coolant was flowing? Fans running???
Old Jun 30, 2014 | 10:46 AM
SLO VETTE's Avatar
SLO VETTE
Got to 260 in about 15 min. Will check on the hoses to see if coolant and fans running, thanks for the tip. If neither what would that be? Does the C5 Z06 Vette have a "limp" mode (reduced power) that it goes into? My '99 did once when the column lock thing engaged (boy was that not entertaining)...
Old Jun 30, 2014 | 11:27 AM
3boystoys's Avatar
3boystoys
Even if there was a limp home mode, I wouldn't chance it. You can take the thermostat out, read what temp it's suppose to open on it, but it in a pot of water with a thermometer and see if it opens when it's suppose to. If it get that hot that fast should be easy to figure out, hopefully it's not a head or head gasket.
Old Jun 30, 2014 | 11:38 AM
dadaroo's Avatar
dadaroo
Really better check out the thermostat. The fans shut off over 35 mph so if it is heating up over that speed the fans should not be the cause.
I would first check the radiator and make sure it did not pick up trash. Not uncommon.
Also could be the temp sensor is bad. Not hard to change.
Please, just DO NOT drive it at that temp in case it is real.
Old Jun 30, 2014 | 11:44 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Ditto on Dadardo
Old Jun 30, 2014 | 12:03 PM
SLO VETTE's Avatar
SLO VETTE
car's in driveway, no issues on driving it anymore. it's never done this before. also, i very quickly hosed off the motor (it was coated with dust) about 30 min before driving it. and i didn't cover the key electrical parts, which i normally do. my mistake. maybe i caused a short somewhere?
p.s. plenty of radiator fluid, it was not bubbling.
Old Jun 30, 2014 | 12:24 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
How about trying a handheld temp sensor? Harbor Freight Tools has them fairly cheap, may not be the most accurate but should let you know if you have an actual temp problem.... I would try it out on something else first, that you know the temp of, just to make sure it is working...
Old Jun 30, 2014 | 12:42 PM
runner140*'s Avatar
runner140*
Things to check...when temps spike:
Check radiator cap (needs to hold 16lbs.)
Check for collasped hoses.
Check for a stuck t-stat.
Make sure water pump is circulating coolant.
Check for debris between the radiator and A/C.(plastic bag/old T-shirt).
Check and make sure there is NO air in the coolant system.
Start with the above...good luck.
Old Jun 30, 2014 | 02:09 PM
SLO VETTE's Avatar
SLO VETTE
fixed.
of all things i just turned on the fan and a/c.
it probably hasn't turned on since last summer.
pcm re-learning as well since battery was completely dead.
thanks a lot for all the ideas.
Old Jun 30, 2014 | 02:25 PM
3boystoys's Avatar
3boystoys
Originally Posted by slo vette
fixed.
Of all things i just turned on the fan and a/c.
It probably hasn't turned on since last summer.
Pcm re-learning as well since battery was completely dead.
Thanks a lot for all the ideas.
huh??
Old Jun 30, 2014 | 02:40 PM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by 3boystoys
huh??
The fans should come on without you having turn on the A.C. This is just some more information to help narrow down the problem.
Old Jun 30, 2014 | 02:52 PM
Chicago1's Avatar
Chicago1
you probably have gunk stuck in the condenser and radiator. You can't just hose it out you need a long air wand that will blow everything out. Way to many threads on this stuff already
Old Jun 30, 2014 | 03:07 PM
SLO VETTE's Avatar
SLO VETTE
you mentioned to check if the fan was running. it wasn't initially.
now it's fine, temps below the 220's as normal range.
huh??
Old Jun 30, 2014 | 03:14 PM
3boystoys's Avatar
3boystoys
Don't get too excited, cars generally don't do 260 one day and "heal themselves" the next.
Old Jun 30, 2014 | 03:18 PM
acroy's Avatar
acroy
also, i very quickly hosed off the motor (it was coated with dust) about 30 min before driving it. .
I bet you shorted out the sensor, and the car is fine
Anyway: VERIFY the car is good before driving it any more!
Old Jun 30, 2014 | 03:42 PM
SLO VETTE's Avatar
SLO VETTE
could very well have been.
car sat outside in sun for a few hours, took it out for half hour to drive and zero issues, temps, etc.
quirky, i guess. and 3boystoys, yep that's a big swing and i will pay close attention to it.
To Temp stuck at 260 - any ideas?
Old Jun 30, 2014 | 03:43 PM
chaase's Avatar
chaase
St. Jude Donor '12
That is my concern. The OP could have shorted a sensor or has a bad relay. IIRC, turning on the AC forces the high speed fans to turn on. They should come on naturally once the car gets to a set temperature though.
If they are not coming on without the AC, then there is still a problem.
Old Jun 30, 2014 | 03:47 PM
SLO VETTE's Avatar
SLO VETTE
they're coming on their own now, no issues.
the car sat outside all winter for the most part and hasn't been driven in several months.
Old Jul 1, 2014 | 07:03 AM
dadaroo's Avatar
dadaroo
Just for input:
Factory temp settings are low speed on at 226 degrees and off at 219 degrees. High speed on at 235 degrees and revert to low speed at 226 degrees. As stated both fans run at low speed and high speed and fans are commanded off by the PCM when the vehicle speed exceeds 35mph.
You can force low speed operation at 185 degrees by turning on the AC. High speed operation with AC on is still 235 degr
