Need headlight help!!!
Old Jul 24, 2002 | 11:46 AM
Al '92's Avatar
Al '92
Default Need headlight help!!!
Pulled into the garage last night and shut off the headlights. They lowered normally but then the left one began making a horrible grinding noise after it closed. Seems like the motor is continuing to run after it closes. Is there an adjustment for this? If it's an easy fix I would rather do it myself than take it to the dealer.
Thanks in advance.....
Old Jul 24, 2002 | 11:53 AM
GaryZ06's Avatar
GaryZ06
Default Re: Need headlight help!!! (Al '92)
I had the same problem(left light) and the motor ran(grinding noise) for about 10 seconds after the lights went down.It needed a new motor(warranty)
Old Jul 24, 2002 | 05:34 PM
Lil Red's Avatar
Lil Red
I had a similar problem where one of y headlights would not close complertely and it was the control module. Luckily mine was under warranty and i'm sure yours will be as well.
Good Luck!
Old Jul 24, 2002 | 05:41 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Need headlight help!!! (Lil Red)
had the same problem, bad motor, dealer replaced it under warranty/
Old Jul 24, 2002 | 05:53 PM
Al '92's Avatar
Al '92
Dayum, sounds like a trip to the dealer then. Good thing it's under warranty. Thanks to all for the responses. :cheers:
Old Jul 24, 2002 | 11:51 PM
redriverjohn's Avatar
redriverjohn
I've had exactly the same problem. You will need to have them replace the actuator/motor control capsule assembley on that side. You're lucky it's in warranty, the part alone lists for $237.00 at the dealer!
Old Jul 25, 2002 | 01:42 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: Need headlight help!!! (redriverjohn)
Hi all,
Al'92, the model years '99 and up have an actuator motor that cannot be opened up and fixed. The problem is a small nylon gear wheel that weakens and breaks after a while. It is the designed weak point in the worm gear drive on the motor. You MUST buy a whole brand new motor, just for this one little thing. Great, huh! :rolleyes:
Steve
Old Jul 30, 2002 | 10:26 AM
GVP3's Avatar
GVP3
Just happened on my 01 (23K miles). Can't wait to see what goes wrong next. :mad
To Need headlight help!!!
