Dead c5 with a p0161 code
Old Jul 1, 2014 | 11:18 PM
Yellow2001c5's Avatar
Yellow2001c5
2nd Gear
Default Dead c5 with a p0161 code
I have never in my life seen an 02 sensor kill a car but it did mine. Car would start but die if I released the clutch. Replaced it and it ran great on the way home. Any of you guys had that problem before?
Old Jul 2, 2014 | 10:19 AM
Yellow2001c5
2nd Gear
It wasn't the column lock because I could drive it for a minute and steer. Also it would die if I revved it holding clutch in. Funny thing is the ses light never came on. My scanner picked the code up.
Old Jul 2, 2014 | 11:14 AM
3boystoys's Avatar
3boystoys
The factory fix(es) can still cause this issue. Column won't lock but the 2mph cutoff still engages. Since you we're not moving I would suspect a short of some kind with the sensor, the revving up must have moved things enough to cause the short.
To Dead c5 with a p0161 code
