Oil pressure sensor
Jul 2, 2014 | 07:56 PM
Brake oil pressure sensor
I'm gaving a hard time trying to take off the brake oil pressure sensor in my 01 coupe.I used a long socket with no luck.Has any body changed one?
Reason: typed wrong
Jul 3, 2014 | 02:04 AM
The oil pressure sensor is at the back of the block, I think the picture you took is not near there
Jul 3, 2014 | 02:06 AM
I followed this when I did mine:
Jul 3, 2014 | 09:29 AM
I used beboggled method from you tube they sell a socket at advanced 1 1/16 its in 3/8 drive. I took me 20 mins...........
Jul 3, 2014 | 01:03 PM
stop what you are doing! You are trying to remove the wrong part! The oil pressure sensor is behind the intake manifold.
Jul 3, 2014 | 01:18 PM
I typed wrong.Its the brake oil pressure sensor that Im having trouble with.I just did the OPS a week ago.
Jul 3, 2014 | 01:58 PM
Quote:
Originally Posted by
lusor
Never heard or seen anyone that had one fail. If you loose fluid out of the ABS module you may have to have the dealer bleed it.
Jul 3, 2014 | 03:18 PM
3boystoys
I have the new part ready to install.Hopefully I can swap them fast enough so that doesn't happen.
