1999 C5 A/C Issue
Old Jul 4, 2014 | 07:21 PM
daustin173's Avatar
daustin173
Cruising
Default 1999 C5 A/C Issue
Sorry - new to Corvettes and this forum. You've probably be inundated with this question, but I haven't found the answer. The A/C blows cold and hot as directed, but it will not change locations. No matter what I input on the control head it just blows out of every outlet. It is the dual zone automatic unit and the control head is new. I'm not mechanical so I will need to take it to a local shop or a dealer. I just want to know what I am looking at for repairs. Thanks!
Old Jul 4, 2014 | 08:41 PM
dmarkshark's Avatar
dmarkshark
There is a small vacuum line from the back of the manifold that can break, or the line continues under the battery and it has a tendency to break due to battery acid. You could probably check both yourself.
Old Jul 4, 2014 | 09:49 PM
knkjens's Avatar
knkjens
Default Driver Side Hot Air
Yup, I've got the problem. Had most of the A/C unit redone by dealer last September, all the way down to the firewall, and had the assembly motors and just about everything else replaced.
A/C worked OK until about a month ago. I checked and have no DIC codes for HVAC.
Couple of questions about some of the procedures that I've read about in here:
1. I've pulled and reinstalled breaker #27 at least 15 times, to no avail. I have seen some threads that say turn the key off, and some say leave it on. Does anyone any more specifics. I've tried with key in OFF, key in ON, with engine off, and with engine running.
2. If I try pulling the negative battery terminal, do I do that with the engine running, and/or what key position.
Old Jul 5, 2014 | 08:37 AM
dadaroo's Avatar
dadaroo
Vacuum controls where the air comes out. Here is a link that might help:
http://forums.corvetteforum.com/c5-t...diagnosis.html
Old Jul 5, 2014 | 08:42 AM
dadaroo's Avatar
dadaroo
You have different issue than the OP. You should have created your own Thread. I don't think you have an actuator issue but you may have lost your A/C charge. Here IS how to reset the actuators:
Re-Calibrating Actuators
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the fuse for the HVAC Control Module (fuse #27 in the I/P fuse box).
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
To 1999 C5 A/C Issue
