MIRROR BLUES
Old Jul 24, 2002 | 04:55 PM
stevep69's Avatar
stevep69
Default MIRROR BLUES
I HAVE A 97 C5 AND THE LEFT (PASSENGER SIDE) MIRROR IS LOOSE FROM THE BASE. THE PART THAT ATTACHES TO THE DOOR IS FINE, HOWEVER , THE PART THAT ATTACHES TO THE NECK OF THE MIRROR IS LOOSE. tHE FIBERGALSS OR PLASTIC PIECE THAT ACTUALLY HOLDS THE MIRROR IS LOOSE FROM THE NECK. IS THERE A BOLT OR SOMETHING INSIDE THAT CAN BE ADJUSTED. dO YOU HAVE TO REMOVE THE DOOR PANEL TO ADJUST IT? anYONE KNOW? :crazy: :confused: :eek: :nonod: :sad:
Old Jul 24, 2002 | 05:14 PM
Lil Red's Avatar
Lil Red
Default Re: MIRROR BLUES (stevep69)
Shoot me an email and i will send a document that has a fix. It's a very detailed document with step by step instructions! It'll also save you several hundred dollars from having to replace the mirror.
Old Jul 24, 2002 | 05:19 PM
stevep69's Avatar
stevep69
Default Re: MIRROR BLUES (Lil Red)
JUST SENT, THANKS
Old Jul 24, 2002 | 05:25 PM
Lil Red's Avatar
Lil Red
You've got mail!
Good luck :cheers:
To MIRROR BLUES
