right head light
Old Jul 8, 2014 | 11:58 AM
jt2004's Avatar
jt2004
Cruising
Default right head light
On my 04 vette the right headlight sometimes will not open. The motor will spin for a second, then stop. If I give it a turn or two manually, it will open. Doesn't do it all the time, just when i'm in a rush to go . Gear, brushes, need lubing??
Old Jul 8, 2014 | 01:34 PM
lionelhutz's Avatar
lionelhutz
It sounds like the gear but typically the motor is jammed and just doesn't move until you turn it by hand.
Old Jul 8, 2014 | 01:38 PM
Chicago1's Avatar
Chicago1
time for a new gear teeth are probably worn down http://forums.corvetteforum.com/c5-g...orialized.html
get the bronze one
Old Jul 8, 2014 | 01:52 PM
Smoken1's Avatar
Smoken1
Gear Time
Old Jul 8, 2014 | 03:40 PM
runner140*'s Avatar
runner140*
Time to purchase a brass/bronze gear....the better kits come with the gear, T brace, grease and great instructions (20 pictures).
I think the kit sells from the net from Rodneydickman dot com
Old Jul 8, 2014 | 05:33 PM
jt2004's Avatar
jt2004
Cruising
ok thanks, that was my guess too, but didn't know if there was a limit switch on the motor that was bent, broke jammed, causing the motor to limit out and jam
Old Jul 8, 2014 | 05:45 PM
jt2004's Avatar
jt2004
Cruising
After looking at this site, you guys are probably 99.9% correct. thanks jt2004
Old Jul 8, 2014 | 06:55 PM
lionelhutz's Avatar
lionelhutz
There are no limit switches inside the motors or anywhere on the headlight assemblies.
To right head light
