Just noticed a few days ago a very slight knocking sound coming from the engine. It's more noticeable when I get under the car, and seems to fade when I get the car going
Turn everything off in the car and drive it to see if you still have the noise most prominant at 1000-1300 rpm.
If it's just the normal cold start that last about 2 minutes or so it's slap and that is normal for the ls1 motor, tho it shouldn't be. A lot of info on it, GM did different things with this motor than previous and post engines
I had A/C off and all that, I had a friend checking it and after a couple minutes he said "wait, I don't hear it anymore." So I'm guessing that's a good sign
