C5 Idle problems with A\C
Old Jul 16, 2014 | 07:58 PM
gmilesfenwick's Avatar
gmilesfenwick
3rd Gear
Default C5 Idle problems with A\C
I’m a Newbie to posting in the forums, but I have read and learned lots about my car before posting. Thank you!
I have a 2000 C5 convertible with 70K miles
I am having idle problems when the A\C is on.
Here are the symptoms:
When cold and when at normal operating temperature, the idle with A\C is fine.
While the car is warming up, approx. between 140 – 190, the idle will drop almost to stall when the A\C is on. Turn the A\C off and the idle is fine. After the car is warm, the issue goes away.
I have done the idle re-learn procedure and it makes the problem better for a few days, then It returns.
Any Ideas would be greatly appreciated. Thanks, Miles
Old Jul 16, 2014 | 08:11 PM
joewom's Avatar
joewom
I have same issue. Has stalled a few times and sometimes if I hit the gas nothing even if I go to the floor. Hit it a few times and it will get gas. only happens with a/c on. Haven't figured it out yet.
Old Jul 17, 2014 | 09:54 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
What type of transmission? If it is a manual the computer does not compensate for AC like it would for an auto.
Old Jul 17, 2014 | 11:18 AM
dadaroo's Avatar
dadaroo
For automatics GM later went to an alternator pulley with a decoupler due to idle issues. Never heard the issue was temperature related but until the engine is up to operating temperature you might be having that issue.
Have you pulled your onboard computer DIC trouble codes to see if there might be another underlying reason?
It does not really "decouple" the alternator but settles out the impact the alternator has on the idle performance. A decoupler can be added to any C5 alternator and just replaces the "plain" pulley. It has no affect on the actual grooved pulley location.
All my info is at home which I can post later if you like.
Here is a picture of what it looks like. Looks like a cylinder just ahead of the pulley.
http://www.ebay.com/itm/02-03-04-C5-CORVETTE-GENERATOR-ALTERNATOR-LS1-LS6-GM-A-C-DELCO-/370661302367?pt=Motors_Car_Truck_Parts_Accessories&hash=item564d22a05f
Old Jul 18, 2014 | 12:12 PM
gmilesfenwick
3rd Gear
Thanks for the information.
I should have included in the original post: Mine is an manual transmission.
I wonder if added this to my car would solve the issue.
Also, I have looked through the codes and found nothing of importance.
I have also cleared all codes and checked after I experienced the problem and there were no codes.
Old Jul 18, 2014 | 02:07 PM
Sigforty's Avatar
Sigforty
Do you have any mods done to the car? It may help by adding it. I personally have the same problem, but have not addressed it yet. I normally keep the AC off on my car until I get the temp up. Now I also have a lot of modifications as well.
Old Jul 28, 2014 | 01:21 PM
gmilesfenwick
3rd Gear
I have an updated Cat-back exhaust.
That is the only mod.
This issue drives me crazy -- I feel like the car will stall, but 99% of the time, it does not.
Turn that A\C and it purrs like a kitten.
Old Jul 28, 2014 | 01:42 PM
mbella2000's Avatar
mbella2000
How do you do an idle relearn procedure? Ever since I disconnected my battery to reset the ac actuator gear motor, now my car idles low when ac is on where it feels as though it would stall out at times....
Old Jul 28, 2014 | 08:38 PM
Sigforty's Avatar
Sigforty
I would start to wonder if something else is wrong. The mods are not enough to make the a suddenly act that way.
Old Jul 30, 2014 | 07:42 PM
uncle wilson's Avatar
uncle wilson
Default mine idles warm 600!?
600 rpm warm ?
To C5 Idle problems with A\C
