2000 Corvette Steering Locked Up
The dealer solution is NOT a permanent fix. You WILL see the problem again...
You could have fixed the problem yourself for $40 plus shipping for an LMC5 aftermarket product that IS a PERMANANT solution....
You came to the Forum TOO LATE to get the help that would have saved you over $750....
4Sievert, stick around here. Lots of talented people on here will help diagnose just about everything about your Corvette. Next time you have an issue, come here first. The 'Stealership' is NOT your friend.
As far as column lock failures are concerned; it's not if it will happen, it's when. They all eventually fail if you do nothing to prevent it.
As mentioned, the fix is cheap and easy. You actually have two inexpensive aftermarket choices for a permanent fix.
1) Column Lock Bypass. The CLB is what I went with 4 years ago and it has been trouble free. Cost me 50 bucks and 30 minutes to install.
2) LMC-5. Fairly new fix that appears to work very well. Does not require you to install anything under the steering column. I believe it all happens at the fusebox.
Any and all dealer recalls are temporary fixes at best. GM never, came up with a reliable fix for this issue.
OP, here is some info on the LMC5. YOU NEED ONE.
I consider the LMC5 to be the best Column Lock problem permanent fix out there. It also does not require you to “undo” any previous CL attempts to resolve this issue. Their eBay ads have a good video that shows the install at the BCM. It does not cover everything in the written instructions. So, read the instructions and also here is some extra info. In some cases, the BCM timing is off just enough to cause some issues. They make several versions and they can swap out/provide one of these if you have any issues. Their customer support is as good as it gets.
Not uncommon for people to "put the column in a pre-lock condition" and not know it and then start with the install. In other words, they started with the column lock “energized’ even if it was not actually locked yet. If not actually locked yet, it will be as soon as you turn the steering wheel after the LMC5 install. It will then remain in the locked condition until you cause the motor to unlock. It will then remain in the unlocked condition since the motor is then unpowered with the circuits disconnected.
Here is one way to prevent that if your column locks and unlocks normally:
If the CL is functioning normally you don't not need the Unlocker, merely turn the ignition ON, pull fuse #23, turn ignition OFF, turn the steering wheel (left and right) and verify it is unlocked. Next, disconnect the negative battery terminal, re-insert fuse #23 and continue with the install.
Compliance Parts website: http://complianceparts.com/index.html
