918 Valve Springs
98 A4
Powerloaded
Donaldson Blackwing
Pro Torque 2400
3.42 gears
Garceeya, your response is the first negative one i have specifically seen here in the forum over the last several months. Can you kindly tell us what exactly happened, after how many miles and what specs on the cam you were running when yours broke? I assume they broke and ruined your heads :U ! Look forward to details. Was there another mechanical failure which was the true cause of your spring failure?
Nitrovette
[Modified by Nitrovette, 2:28 PM 7/25/2002]
98 A4
Powerloaded
Donaldson Blackwing
Pro Torque 2400
3.42 gears
Nitro
:cheers:
-Tuan
despite the fact that you personally had an issue with yours, the VAST, OVERWHELMING majority have found them to be relatively bulletproof, assuming they're installed correctly.
Comp Cams designed these springs specifically for the LS1--no other spring is.
The track record of only a handful of failures, out of the hundreds, if not thousands more, that have had no issues with them at all, speaks volumes--
I run them to 7000RPM pretty regularly, and you can see from my sig that I'm not using a baby cam---
918's are the best choice out there for almost everybody---
Period:)
:cheers:
That's an irrational and biased position :nono: --
Period:)
:cheers:
Nitro
Regards
Randy goss :cheers:
I´m sure most (if not all) are!!
My 918 work perfect, and I have run them up to 7000rpm´s.
I don´t remember posts from A4´s having failed 918`s.
Michael
Regards
Randy goss :cheers:
CompCams may, or may not, stand behind things. While the 918's seem less prone to breakage than the 941's, I do think both are highly suspect, especially in more aggressive application.
Let the buyer beware, and BE CAREFUL. Before my most recent update, I had asked my engine builder about dual springs. He chose the 918's for a variety of reasons. Boy do I wish he hadn't!!
[Modified by SPEED DOG, 7:28 AM 7/31/2002]
98 A4
Powerloaded
Donaldson Blackwing
172 t.stat
Pro Torque 2400
3.42 gears
[Modified by Mitch C, 11:43 AM 7/31/2002]
When Chris@SpeedDemon put the stage III heads in my car two days ago, the 918 springs and valves on the stock heads (from MTI T1 cam package) are still looking great. And that's is after 8K miles with countless number of bottles through them.
:cheers:
-Tuan
