C5 Z06 problems
Old Jul 20, 2014 | 04:35 PM
gschub's Avatar
gschub
Default C5 Z06 problems
I am looking to purchase a C5 Z06, however, I want to know the most common problems, i.e., Bad valve springs in the 2002-2003 models, clutch's sticking to the floor requiring fluid change, ignition problems, etc. Thanks for your input.
Old Jul 20, 2014 | 06:12 PM
Supercharged111's Avatar
Supercharged111
Clutches sticking to the floor requiring new clutches is more like it. Some people do the drill mod in an attempt to alleviate the issue, but a POS pressure plate is often the cause as well. There are many 11" options, but I myself want a 10.5" solution. Some people have issues with the fill tube on the tank leaking, but that one doesn't seem to be as rampant as the first 2. The constant boner you'll have driving the car can be annoying at first, but you get used to it after a while.
Old Jul 21, 2014 | 12:54 AM
racebum's Avatar
racebum
valve springs and the potential clutch, and the hvac screen repair are about it
other than general age related items like water pumps, shocks etc they are really trouble free
valve springs are cheap too. 65 dollars a set
Old Jul 22, 2014 | 07:57 PM
REDZED2's Avatar
REDZED2
Tick Master cylinder for your clutch fixes the clutch pedal sticking to the floor issue permanently! No matter what clutch you have!
Old Jul 22, 2014 | 09:55 PM
dr_whigham's Avatar
dr_whigham
No it does not. Call Tick yourself and ask them. Ask for either Joey, Martin or Jonathan. They'll even tell you you're fighting the stock GM POS self adjusting pressure plate.
Get an aftermarket clutch and be done with it.
To C5 Z06 problems
