Cleaning grounding points
Old Jul 22, 2014 | 09:01 PM
SoAlVette's Avatar
SoAlVette
Default Cleaning grounding points
Going to check my grounding points for corrosion. Does the battery need to be disconnected to do this?
Old Jul 22, 2014 | 09:51 PM
Mastertvtech's Avatar
Mastertvtech
Highly recommended.
Old Jul 23, 2014 | 11:30 AM
dadaroo's Avatar
dadaroo
I agree with the above statements. Some people use dielectric grease in the reassembly which is fine to help prevent moisture intrusion.
However, this grease is an INSULATOR so do not put it in the actual current path. Put is around the current path and you will be fine.
You can use a good electrical contact cleaner also. Easy to get in spray cans.
To Cleaning grounding points
