Serice Active Handling help
Old Jul 23, 2014 | 09:00 AM
ttz's Avatar
ttz
Default Serice Active Handling help
My DIC keeps showing service active handling. I know this is a somewhat common problem, but am not sure if it's the BCM or simply a sensor or something else. It comes on just about any time I drive it now. Recently started about a month ago and has progressively become more frequent. It'll reset after the ignition is off but it'll then later come on again at a random time. I cleared all codes and the following popped up after it came on:
U1064-Lose of Communications with DCM
P0102-Mass Air Flow (MAF) Sensor Circuit Low Frequency -A (doubt this is related as car is on SD tune)
C1288-?
Any ideas where to start?
Old Jul 23, 2014 | 10:12 AM
3boystoys's Avatar
3boystoys
C1288-?
Try search, MANY, MANY posts on this. You'll need to pull your codes from the DIC first.
Old Jul 23, 2014 | 10:30 AM
Smoken1's Avatar
Smoken1
C1288 Steering Position Sensor Circuit
Old Jul 23, 2014 | 12:44 PM
jrose7004's Avatar
jrose7004
When my 04 coupe started doing that, I need to replace the steering sensor. Once I did that the problem disappeared.
Old Jul 23, 2014 | 01:34 PM
coia96vette's Avatar
coia96vette
Yep the code C1288 is for the SWPS. If you have a 01 to 04 you can still get them new. For the earlier ones you can not.
Old Jul 23, 2014 | 02:21 PM
ttz's Avatar
ttz
Its an 01 Z06. I'll try swapping out the SWPS first. Thanks.
Old Jul 23, 2014 | 10:21 PM
coia96vette
Got mine for my 04 from Gene at www.gmpartshouse.com. Costs about $65 and took about 2.5 to 3 hours to replace. Just be careful with the airbag. There is a good write up on this forum on how to do it.
To Serice Active Handling help
