Help!!Chirping sound
Old Jul 25, 2002 | 11:15 PM
F0duncan's Avatar
F0duncan
Default Help!!Chirping sound
Well I just got my 98 vette about a month ago and have noticed that when it shifts(I have and automatic) I hear a small short chirp sound. It does not do this every time and really i have no clue what it could be. Any help would be greatly appreciated. Thank you.
Old Jul 26, 2002 | 01:05 AM
DC5's Avatar
DC5
Default Re: Help!!Chirping sound (F0duncan)
Could this be a good thing.. as in tire spin?? Chirp away Willa. If you were being serious, my apologies. :cheers:
Old Jul 26, 2002 | 02:25 AM
F0duncan's Avatar
F0duncan
Default Re: Help!!Chirping sound (DC5)
No sorry to say i am serious. The sound seems to be coming from the engine.
[Modified by F0duncan, 6:47 AM 7/26/2002]
Old Jul 26, 2002 | 04:29 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Thats when the tires grab and slip on the road because you have too much power under that hood.
Save some for the track!
Old Jul 26, 2002 | 05:25 AM
Oskee's Avatar
Oskee
Veteran: Marine Corps
I know the 97's had a revised idler tensioner because of the noise they made. Have you looked at your serpintien belts ? My buddie with his 98 C5
had a chirp comming from his motor so we cleaned all the pully groves and replaced the belts all this at 45K miles and his chirping has not returned.
Hope this helps...................... :cheers:
Old Jul 26, 2002 | 09:43 AM
1999 White C5 Coupe's Avatar
1999 White C5 Coupe
F0duncan,
There is a TSB for 1997 - 1999 Corvettes, and 1998-1999 Camaro & Firebirds equiped with the LS-1 engine. It involves replacing the idler pulley because the bearing race was crushed upon assembly. The new pulley has a thicker race.
The idler pulley was replaced by my dealer under the new car warranty and it eliminated the "squeak" or "chirp". It could also be heard at idle.
Good luck.
Old Jul 26, 2002 | 06:01 PM
F0duncan's Avatar
F0duncan
Default Re: Help!!Chirping sound (1999 White C5 Coupe)
Thank you everyone ill go and try to get this fixed right away.
Old Jul 26, 2002 | 11:22 PM
1999 White C5 Coupe
F0duncan,
The TSB is #99-06-01-007, "Accessory Drive Squeak (Replace Idler Pulley). It instructs the dealer to replace the idler pulley with a new assembly, part #12564401. The labor time allocated is 0.3 hours. Good luck.
To Help!!Chirping sound
