I have a 2000 that I'm about to install an A&A kit on so I'm probably going to need better cooling with the higher speeds at the track. I've had an early version of the DRM brake cooling duct extenders but they've been worn down by the tires on tight turns. I'm running 275R18 up front.
Any recommendations on brake cooling that will have minimum interference with the tires?
I would be more concerned with with how your pistons may hold up at the track if your are running FI with stock pistons.
Brake pad research would probably be a lot more useful than better cooling ducts than DRM.
If the stock pistons don't last I'll swap the short block again next year. Didn't have the budget to go forged this time around.
I usually run Hawk HP Plus or PFC 01 if I'm running race tires. Hava pad you recommend?
Gotta be honest here, never drove on a track in my life. Never built a motor in my life. . i was just trying to answer you with common sense based on what I have only read on other posts and provoke a thought process to your question. I have no place in making any recommendations.
You should do a search as there are a plethora of recommendations and ideas out there. However, I would say that with FI your speeds will need MUCH better pads than Hawk HP+. Those pads SUCK and will fade. Some groups have even gone so far as either outlawing them or strongly discouraging using them. They really are a beefed up street pad and you would be better with something like a Carbotech XP 8 or better pad. Cooling is a worthwhile effort but you should also upgrade your pistons on your calipers to SS instead of aluminum which will reduce heat transfer to your brake fluid. Obviously switch to Motul RBF 600 or Castrol SRF fluid as well. Check out the thread/sticky of "HPDE what I have learned" and it discusses all this.
I don't have ducts, but have always run decent pads like XP12/10, DTC70/60 etc.
A few years ago I installed an AP T1 caliper kit on the front. The pads are way significantly cheaper and substantially thicker than the stock Corvette pads. I run the least expensive blank NAPA type rotors as I don't believe that any of the more expensive brands really last much longer before they crack.
With the new calipers I can pound on the brakes for 20 minute sessions at Blackhawk, Road America, GingerMan or Autobahn without any change in brake feel. Sometimes I don't even bleed brakes after an event.
From my experience, I would say that the order of importance would be calipers, pads and ducting last. If you can keep rotors from cooling too fast after coming off track, that is worth something. ie. don't park sideways to wind on a chilly day. That increases odds of cracking the windward side.
First of all you need to start hanging out on the Autocross and Roadracing page in the general section. All of your questions about what to do with brakes and tracking have been answered over there numerous times.
While better pads will no doubt improve your brakes, you need a set of brake cooling ducts and a set of spindle ducts to get the air right on the rotors. Everything else is just wasting your time and effort. After a couple of track days of overheating uncooled brakes your calipers will spread and then you will have even more cost to fix it right.
There are plenty of how to threads on the autox and RR page covering brake upgrades, but just putting a set of pads on it isn't going to get it done. You really need to get the heat out of the brakes and that takes some cooling ducting.
