Mine is a 1998. Just wondering why my headlights will dim when using the power windows and sometimes brakes. I'm getting a reading of 13.6 to 13.9 volts on the dic. Any ideas?
OP's first car with power windows hahaha.
In all seriousness, some cars even do it when turning the steering wheel
No No not my first with power windows. Haha All of my other cars have them but none of them do that at least not bad enough that I can notice like in the vette. Im not concerned about it just wondering if there was anyone out there who had a similar problem and had an easy cure.
Cure for power windows drawing current? Don't use power windows when headlights are on. Even better, don't pay any attention to the lights when you push the power window button. You can add bigger wires and clean grounds and connections, but you're trying to fix a problem that isn't a problem.
Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
