Looking for a Fuel Pump
Old Jul 28, 2014 | 10:02 AM
HardcoreABN's Avatar
HardcoreABN
Default Looking for a Fuel Pump
Apparently a 255LPH is the largest I am going to fit in the factory module while keeping proper jet pump operation. I was looking at the LPE package, but it is only a 225 LPH pump....Racetronix says they sell the same pump but it is a 255LPH pump.
Are there any options besides these 2? Car has the early style rear mount module. I don't want to spend a ton- If I spend a lot I would rather just upgrade to the new style and run the Aeromotive module.
Old Jul 28, 2014 | 10:13 PM
Russ K's Avatar
Russ K
The LPE pump is rated at 60 psi, and I'm sure the the Racetronix is the same pump but is rated at 43.5 psi.
Russ Kemp
Old Jul 28, 2014 | 10:30 PM
StingrayRebel's Avatar
StingrayRebel
what kind of power are you making?... the racetronix pump might be all you need... their pump harness is also a nice piece, I suggest getting that too if you don't already have one
Old Jul 29, 2014 | 01:29 AM
LoneStarFRC's Avatar
LoneStarFRC
Buy the Racetronix RFPK-007 kit and be happy. It contains the pump and direct-feed hotwire wire harness (plug-n-play). UNLESS you're over 600 RWHP, you're good. You'll love their quality as well.
Tip: Shop around their distributors for the best price on the kit. Prices vary, but you should be able to get it for low 200 range.
Old Aug 1, 2014 | 05:00 PM
HardcoreABN
I am at 475rwhp now, once I get the bugs worked out I fully expect to be 525-550 range NA. Also spraying up to 250 on top of it. Think I might just say screw the fuel bucket and go with a 450 lph e85 pump
Old Aug 1, 2014 | 07:33 PM
NukeC5's Avatar
NukeC5
I think they are the same pump. But with the racetronix harness, it up's the pumps output. I just ordered the LPE pump kit and racetronix harness. LPE says the pump is good to 600. It's probably more with the harness.
Old Aug 1, 2014 | 07:36 PM
HardcoreABN
I was thinking of that 1, but that would still leave me needing to replace the BAP that **** out so I would have enough fuel for the nitrous system lol.
Old Aug 1, 2014 | 07:42 PM
NukeC5's Avatar
NukeC5
Good luck on your setup. Im doing a 150 shot on top of my 430whp. So this kit should do the trick for me.
Old Aug 1, 2014 | 07:46 PM
HardcoreABN
I'm at 475 now and once I work the kinks out I should be 525-550. That would put me on the edge just NA. Can spray up to 250 on top of it lol....
Old Aug 1, 2014 | 08:45 PM
LoneStarFRC
Might want to give Lonnie's Performance a call. He's got some good fuel system stuff.
To Looking for a Fuel Pump
