Instrument trim panel
Old Aug 1, 2014 | 04:59 PM
cdnwillyg's Avatar
cdnwillyg
Default Instrument trim panel
Quick question, is there a holding tab top right corner of trim panel? Mine seens to be a little to far away from a good fit and was wondering if that tab maybe broken or ????? Pic would be nice.
Thanks in advance.
Old Aug 2, 2014 | 01:00 AM
SG Lou's Avatar
SG Lou
Thanks in advance.
How about you posting a picture so we can see what you're talking about. Trim Panel is a very general term.
Old Aug 2, 2014 | 01:15 AM
65GGvert's Avatar
65GGvert
It's very common. If you go to Google and search for C5 radio bezel or console trim fit, you'll see several suggestions. If you hook your fingers under the bottom flat side of the bezel just to the right of the traction control button (the back of your fingers will be touching carpet) and lift up, you'll see that that corner pops back in. Some have put something under the panel there. Some have glued something to the top right corner for friction. You may not believe it but you're probably the only one who notices it. I only notice mine when I'm looking directly at it and wishing it fit better, passengers don't notice. If it's a black interior, you can put a black background in there and it won't show up as much. Lots of owner's don't even notice unless they remove their bezel to work on the radio or HVAC, then feel like they put it back in wrong or broke something. They warp on their own. You just have to find some way to create enough friction on that upper right corner to keep it from popping out slightly.
Old Aug 3, 2014 | 12:39 AM
cdnwillyg's Avatar
cdnwillyg
It is the trim that goes up the center console around the radio. Top right hand corner sticks out.
Old Aug 3, 2014 | 12:41 AM
cdnwillyg's Avatar
cdnwillyg
When you say pops back in, is it because something has let loose or is it just the pressure just moves the top right corner back into place and there is no attachment there?
Old Aug 3, 2014 | 02:11 AM
SG Lou's Avatar
SG Lou
Ohhhhh the center console bezel ...I know exactly what your talking about as mine is loose as well. There is a tapered pin, sort of resembles a the shape of a christmas tree, thats cast into the back of that corner. It gets pressed into a bushing and hold the corner in place. That pin is probably broken off and thats why the corner is loose. I have yet to find a way to secure that corner...unless you want to buy a replacement console bezel !
See the yellow circle? that's what i'm talking about. And from the looks of it that pin is also broken off partially
Old Aug 3, 2014 | 05:51 AM
65GGvert's Avatar
65GGvert
It will be loose there whether the pin is broken or not. It was just held in by friction. Unless you can come up with some way to make it "snap" in or lift on the rear of the bezel at the bottom, it will stick out some. Some more than others. It was poorly designed and if you can come out with a fix other than what I told you, a lot of people can benefit. It's been a long time since I've seen one that didn't have at least a small gap there. The "pin" circled in the picture isn't what holds it in, that's just a guide that goes into a hole. The clip above it is what should keep the top tight, but doesn't after a while.
Old Aug 3, 2014 | 07:58 PM
cdnwillyg's Avatar
cdnwillyg
Thanks for the info, will try to fix and if successful will share.
Old Aug 3, 2014 | 08:10 PM
bjones7131's Avatar
bjones7131
I have noticed the same problem on my 01
Old Aug 4, 2014 | 08:41 AM
TexasRob's Avatar
TexasRob
I have an '03 Z06 and had the same problem. There are two tabs at the top of the bezel. I used a heat gun to soften the plastic tab and bent back up towards the top of the bezel. Snapped back in with a much more secure fit.
Old Aug 4, 2014 | 12:15 PM
cdnwillyg's Avatar
cdnwillyg
Do you think appling velcro tape would make that a tighter fit? It would still be removeable yet hold tight to the dash.
Old Aug 4, 2014 | 12:54 PM
65GGvert's Avatar
65GGvert
No, I don't think Velcro will hold it in. The bezel is too rigid. When you tighten the two nuts at the bottom, the top will pull out. I put a rubber block under the panel at the bottom and tightened the bezel against the block instead of the hump and it helped. Still not as snug as it should be. You really need to have a way for those top snaps to grab something. You might be able to modify or make something that the tab can grab on to in the dash part. I didn't put that much effort into it because no one else in the car but me even notices.
To Instrument trim panel
