Help solving somewhat dissapointing low Dyno results
Old Aug 9, 2014 | 03:46 PM
markh1977
Ok so I took the car to the northstar dragway (1/8 mile) in denton,tx last night. Here are the results. Keep in mind that this was my first time drag racing on a track.
pass 1
60' - 2.0372
330' - 5.4452
1/8 ET - 8.1955
1/8 MPH - 88.76
pass2
60' - 2.0051
330' - 5.4009
1/8 ET - 8.1340
1/8 MPH - 89.5
pass 3
60' - 1.9727
330' - 5.3682
1/8 ET - 8.1071
1/8 MPH - 90.4
Do these numbers correspond with Dyno results and mods?
Thanks for all the replies!
Old Aug 9, 2014 | 04:05 PM
racebum's Avatar
racebum
pass 1
60' - 2.0372
330' - 5.4452
1/8 ET - 8.1955
1/8 MPH - 88.76
pass2
60' - 2.0051
330' - 5.4009
1/8 ET - 8.1340
1/8 MPH - 89.5
pass 3
60' - 1.9727
330' - 5.3682
1/8 ET - 8.1071
1/8 MPH - 90.4
what was the air temp and humidity? you can have just drastic changes in time based on weather. i don't really follow 1/8th mile and have always done 1/4, but, if it was humid as hell and really hot, it would explain it
i actually just dug up one of my old time slips. this was a completely stock 2002 z06 on a hot hot *** day. early sept of last year. 8.253@87.13mph
if you're making peak power at 6300-6400 the cam is what it says. if you had a lot of time and money you could experiment. typically, i've noticed auto cars really take off with a lot of overlap. a 110LSA cam with the same duration may peak 500 rpm earlier, but, the midrange is stronger. with autos, that just seems to be fast. at the same time you would have more lope and it wouldn't be as cruiser friendly, also would never pass emissions
Old Aug 9, 2014 | 06:11 PM
markh1977
It was probably about 85deg and high humidity. It had rained a few hours earlier and the start of racing was delayed because they were drying the track.
Old Aug 9, 2014 | 10:22 PM
racebum's Avatar
racebum
would not be surprised to see your car run 92mph in the 1/8th in october, possibly 93
i wouldn't sweat trying to chase every last hp. if you want to do that the sooner you buy turbos or a supercharger the better
so much goes into drag racing, especially with an auto, your stall has a MAJOR impact on 1/4 performance, weather affects everyone.
are you happy with how the car feels? that's what really matters.
Old Aug 13, 2014 | 11:47 AM
enoniam's Avatar
enoniam
Seems a little light to what my car just did on a Mustang dyno last month - 380 rwhp @5250, 383 ft-lbs @4600, which is supposed to read about 10% less then a dynojet. I bought the car at a Mecum auction so not sure about cam specs - but it sure doesn't sound like a stock cam. Stock heads, Weiand/Lingenfelter intake manifold, long-tube headers, guessing corsa indy pace car exhaust. When I bought car had a dorked-up computer tune - car was running leaner than stoich at WOT. I at least got it richer than that but dyno wideband showed it at best around 14.0 during the run. I've since of course dialed in more WOT fuel so it may be a bit stonger now. During the run injector duty cycle peaked at 90% so I don't have a lot more there to go with those injectors.
Old Aug 14, 2014 | 12:33 AM
racebum's Avatar
racebum
that's dangerous for ringlands going that lean at WOT
would be careful until you get that sorted out
Old Aug 15, 2014 | 11:26 AM
enoniam's Avatar
enoniam
When I got the car it had the Long Term Fuel Trims turned off, and the short trims were running into the positive teens pretty much across the board. Going into Power Enrichment mode the computer doesn't do the short term trims so it was running quite lean at WOT due to that, and the Power Enrichment added fueling tables seemed a bit on the light side as well. First things I did to the tune included turning the long term fuel trims back on and adjusting the MAF calibration to get them running a bit on the negative side. After seeing the 14.0 and up on the dyno I've added a bit more to the MAF calibration in the higher airflow region and added about another 10% more extra fueling in the Power Enrichment added fueling table. Not sure where it's at now but should be well down into the 13s for AFR or lower.
Old Aug 15, 2014 | 12:08 PM
jb35007's Avatar
jb35007
first i would definitely call out the bottle neck!!!!!! 30# injectors!@#$%
you are starving it for fuel imo i'm running 60# injectors on 7lbs of boost and my tuner says i am at my limit and could actually use bigger injectors or upping the fuel pressure.
secondly question on dyno results and some of the responses what does gear ratio have to do with power results??? i would think that 3.73's and 4.11's would have the same h.p. and torque numbers???? i understand having heavier wheels making a difference being more mass but how would gear ratio effect h.p. and torque???
and if it does make a difference would making the dyno pull in 4th gear 1:1 or 6th gear that is like .5:1 make different readings???
Old Aug 15, 2014 | 12:59 PM
enoniam's Avatar
enoniam
That's a good point - he's needing more than 30# injectors to see his target hp or quite high fuel pressure feeding them. Did the dyno not record AFR???
Old Aug 15, 2014 | 01:58 PM
igtabg1's Avatar
igtabg1
pass 1
60' - 2.0372
330' - 5.4452
1/8 ET - 8.1955
1/8 MPH - 88.76
pass2
60' - 2.0051
330' - 5.4009
1/8 ET - 8.1340
1/8 MPH - 89.5
pass 3
60' - 1.9727
330' - 5.3682
1/8 ET - 8.1071
1/8 MPH - 90.4
FWIW im runing a little bit bigger cam 231/239 on 113 with a 3600 stall, and personally i think i need a lot more seat time im running a 7.75 in the 1/8th. Get bigger stall and great tuner. Or throw a turbo/ nitrous/ supercharger and be done lol. Hows the prep at northstar?
Old Aug 16, 2014 | 02:01 AM
markh1977
That was my first time to drag race on a track. I have nothing to compare it it to. However, people I know that visit tracks regularly say its one of the best for track prep.
Old Sep 11, 2014 | 03:57 PM
markh1977
OK so I have an update and a couple questions.
As suggested by most on this thread.....
Replaced my stock MAF with 01 Z06 MAF
Replaced 78mm TB with 90mm LS2 TB.
I was wanting to beef up the Cam a bit more.
Im looking at the Texas Speed magic stick (3) 237/242 111 LSA.
Will also be swapping the stock stall converter for a yankSS 3600
Upgrading fuel pump to either the Racetronix model#(????) or LPE fuel pump
replacing 30# injectors with 39#-42# injectors.
Should these mods mesh well with my other mods? Is the magic stick 3 considered a "big" cam? Any better recommendations? Im really not concerned about fuel mileage/ emissions/ or comfort, just BIG POWER and Lower track numbers and being able to drive it on the street (comfortable or not). I prefer the opposite of sleeper.
Thanks in advance for any help!
Old Sep 12, 2014 | 12:14 AM
  #33
dagon138's Avatar
dagon138
That seems like a pretty freaking big cam to me, but we're used to little smog cams here in Cali... BTW my stock 02 z06 injectors were slightly over 80% duty cycle at 450rwhp.
Old Sep 12, 2014 | 06:30 AM
  #34
BigBirdLS1's Avatar
BigBirdLS1
Stock stall with a cam that size is why your car feels lazy coming off the line. You aren't getting in your power band as quickly as it should be. BTW I have that exact cam in my C5Z my car made 455rwhp but it started with ~50 more HP than you did. So your #'s are where they should be.
STALL the car and it will be a whole new car.
Old Sep 12, 2014 | 06:56 AM
  #35
ZZ06's Avatar
ZZ06
ZO6 injectors were 28.5lb. Either way, you definitely need more fuel. I was bolton and cam only and at WOT i was around 92%. WAY over the safe mark of 80%.
Old Sep 12, 2014 | 02:20 PM
  #36
RonSSNova's Avatar
RonSSNova
If it follows commanded AFR through out the rpm range, you are "ok". But I agree 28 lb/hr is not quite enough.
I have LS2 in mine which are 33lb/hr and I get just past 90% duty cycle.
Good move on the TB, MAF and esp the Yank 3600.
That will completely wake up the car.
Don't touch the cam.
For comparison. My car has AFR 205 heads, smaller 226/230 114 cam, same TB/MAF, Fast 102 intake, Yank-me SS3600 with 3.42 gears and runs bottom 11's in cool air. Best of 10.99@123.7.
1/8 best is 6.99@100
Have fun! And do let us know how she does!
Ron
Old Sep 12, 2014 | 11:38 PM
  #37
martysauto's Avatar
martysauto
St. Jude Donor '14
Ron
100%. Listen to Ron! His set up isn't radical, it just works, really well!
Old Sep 13, 2014 | 12:35 AM
  #38
RonSSNova's Avatar
RonSSNova
You are too kind Marty.
