Dic code (o2 sensor) question and advice
Old Jul 26, 2002 | 07:48 PM
AlphaKnight34's Avatar
AlphaKnight34
Default Dic code (o2 sensor) question and advice
I was driving along and got a check engine light along with a 'P0133'. Looked it up and found out that it is a 'Heated Oxygen Sensor (HO25) Slow Response Bank 1 Sensor 1-B'. I am not that concerned because the car still seems ok. I did a search, and found out this is fairly common. In doing the search I found that it may be because I still have on my test pipes from my header install (Tuan Le had similar situation). Is this the right direction?? Can I still go to the track ( I don't think it'll harm anything but I want to be relatively certain. Is there anything else I need to do?? Thanks :chevy
Old Jul 26, 2002 | 10:25 PM
AlphaKnight34
Default Re: Dic code (o2 sensor) question and advice (AlphaKnight34)
:confused:
Old Jul 27, 2002 | 01:44 PM
AlphaKnight34
Default Re: Dic code (AlphaKnight34)
:confused: :confused: :confused:
anyone?
Old Jul 29, 2002 | 12:24 AM
AlphaKnight34
ttt
To Dic code (o2 sensor) question and advice
