P0103 help
Old Aug 11, 2014 | 10:52 PM
Khkingpin's Avatar
Khkingpin
Default P0103 help
So I have seen there were other post on the code, however none really seem to apply to my particular situation. I have a 98 vette with a blower and I am running speed density, so I don't have a maf sensor. This code seems to be directly related to a maf, when my car was tuned it was switched just for speed density. So the problem I am have is I no longer have 3rd or 4th and I know everyone will say the are weak, which I understand, however I am wanting to try and get this cleared just to see if I can be lucky for once. Any ideas will help help, I'm not sure if a PCM can lose a tune but hey you never know if you don't ask. I also know that this code can cause shift problems in early ls1 platforms, which is what I'm hoping for these things are pricey.
Thank you in advance
Old Aug 12, 2014 | 10:21 AM
3boystoys's Avatar
3boystoys
Tune can't be "lost", it's a EEPROM, it's only ELECTRICALLY ERASABLE i.e. it has to be erased by a tuner/Tech II. Time to visit you tuner again.
