Clutch Question ??
Old Jul 27, 2002 | 11:41 AM
soapy's Avatar
soapy
Default Clutch Question ??
As a new C5 owner (2000 6-speed Coupe) I’m wondering if my clutch is normal or if there may be a problem. The engagement point when releasing the clutch varies tremendously from lets say a ¼ from the floor to 7/8 from the floor. I’m used to a manual clutch (on my 1970 LT1) which has a lot of feel. Maybe this is just characteristic of a hydraulic clutch ? There is also only 9000 miles on the car.
Thanks in advance for any help. This is a great Forum !!!
Old Jul 27, 2002 | 07:47 PM
Snowblind's Avatar
Snowblind
Default Re: Clutch Question ?? (soapy)
That does not sound right, my clutch seems to engage at around the same point all the time. You should still be under warranty, so I would take it in.
Old Jul 27, 2002 | 07:58 PM
luvinc5's Avatar
luvinc5
Default Re: Clutch Question ?? (Snowblind)
This tends to be a problem among some mn6 vettes. Bring it to the dealer.
Old Jul 28, 2002 | 08:57 AM
soapy's Avatar
soapy
Default Re: Clutch Question ?? (luvinc5)
Thanks for the help....I'll let the dealer look at it.
Old Jul 28, 2002 | 10:38 AM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
Sorry no answer for you, but welcome to the forum.
P.S. Try doing a search.
[Modified by pjazz, 9:38 AM 7/28/2002]
Old Jul 28, 2002 | 11:40 AM
kh24's Avatar
kh24
Get it looked at right away. Mine always engaged high and that led to lots of wear. My clutch blew out at 5600 miles because of that( and a couple of bolt on mods) Tell the dealer it never engaged right and you want it replaced with the Z06 clutch. Good luck. :cheers:
Old Jul 28, 2002 | 12:22 PM
steve badalamenti's Avatar
steve badalamenti
Chevy, for obvious reasons, designed in a physical restriction into the
slave cylinder hydraulic line. So, the faster you release the pedal,
the more the clutch will APPEAR to be late in engaging. If you
try to pop the clutch with the traction control switched on, all you
will see is smoke....not from the tires, but from the CLUTCH !
Try SLOWLY releasing the clutch repeatedly, and you will
see that it actually is engaging at the same point every time.
Now, release it faster, and the engage point will seem higher up. See ???
Lots of folks here have drilled out the restriction, but it is a LOT of
labor to even get to it.
Old Jul 28, 2002 | 10:53 PM
Pat97Vette's Avatar
Pat97Vette
Soupy,
I've had the same problem now for 6 months. However, I had hard shifts and gear grinding when the clutch would release closer to the floor. My clutch was not disengaging. It's a 97 with 30k miles on it. I owned it for the past 2 years.
I first bled the clutch and that fixed the problem, for a while. Then, I replaced the master cylinder with a modified line for less fluid restriction and that fixed the problem, for a while. The last straw was the slave cylinder. I've had issues with trying to get it repaired under extended warranty. A new slave requires new clutch which I got the run-around from GM about who's gonna pay for it. I was convinced it was a hydraulic issue.
Get this - two weeks ago, a friend of mine was bugging me to let him drive the car. I gave him the keys and 15 minutes later he came back and it was fixed! What the heck? He said he was popping the clutch and power shifting. I was ticked off that someone drove the car hard but was happy that it was back to "normal." Maybe I had some dirt or something on the seal of the slave cylinder? It's been fine ever since!
Let me know if you decide to let the clutch pedal fly and power shift and if this fixes your problem. I'd be quite curious if it does.
Pat
[Modified by Pat97Vette, 8:56 PM 7/28/2002]
Old Jul 28, 2002 | 11:20 PM
MDT's Avatar
MDT
Default Re: Clutch Question ?? (Pat97Vette)
Pat97Vette,
I'm gonna take a WAG here and say that possibly when your friend had the car out putting her through her paces, that the automatic take up on on the clutch suddenly broke loose and adjusted itself so that the throwout bearing was in closer proximity to the clutch plate fingers.
A greater than optimum distance as cited above could certainly explain the low engagement/release point, I believe.
As I recall, c4c5 specialist posted a long time back, how to do the adjustment manually, by using a couple of screw drivers.
Whatta ya think? Maybe? Anyway, lets hope she stays fixed this time and maybe one of the techs can elaborate.
Good luck.
Mark
Old Jul 29, 2002 | 08:50 AM
Pat97Vette's Avatar
Pat97Vette
Default Re: Clutch Question ?? (MDT)
You're probably right - I have no clue how the actuator's built or how it's supposed to work. I searched for the c4c5 post you mentioned but can't find it. Thanks.
Old Jul 29, 2002 | 10:02 AM
MDT's Avatar
MDT
Pat,
I think I have read something about it somewhere...probably in the service manual.
Mark
Old Aug 6, 2002 | 07:31 PM
dcronkhite's Avatar
dcronkhite
Interesting discussion..
I'm having a Z06 clutch/slave installed in my '97 this week.. Anyone run into issues with this setup at all?
To Clutch Question ??
