Headlight Pop Up Problem
Old Aug 17, 2014 | 07:36 PM
VetteDiva2003's Avatar
VetteDiva2003
6th Gear
Default Headlight Pop Up Problem
First the left headlight stopped popping up with I turned them on. A friend cleaned the gear. Now when it pops up but makes a grinding noise like the motor is still trying to close the light when it pops down. Any ideas? Originally someone told me the gear teeth are notorious for wearing down and I should replace that. I don’t want to go to the Repairman and he rip me off. I live in Redmond, WA - any good mechanics you can recommend?
Old Aug 17, 2014 | 10:11 PM
corvette77's Avatar
corvette77
Headlight gear is stripped, VERY common problem. Get a brass gear and replace it yourself, it is an easy DIY project.
Old Aug 18, 2014 | 12:23 AM
VetteDiva2003
6th Gear
Default Headlight not popping up correctly
is that the exact name of the part? I am assuming I can get that from Chevy? Any manuals to show how to do it? Thanks!
Old Aug 18, 2014 | 01:08 AM
BigGun's Avatar
BigGun
I think Chevy wants to sell you the complete headlight. The gears are readily available from a number of after market venders. Search "C5 headlight gear replacement" using google and you should get a number of hits.
Old Aug 18, 2014 | 07:58 AM
runner140*'s Avatar
runner140*
Take a look at "rodneydickman dot com". They sell a kit that is complete with brass gear, "T" brace, epoxy, grease, and plenty of instructions with pic's. Think about buying two...the other one will also go.
Old Aug 18, 2014 | 02:10 PM
VetteDiva2003
6th Gear
Thanks - found it on Amazon for $50each, and a video on how to install on YOUTUBE! Thanks!
Old Aug 18, 2014 | 02:12 PM
VetteDiva2003
6th Gear
WOW! Wish I saw your email sooner - Rodney’s site is $40 and Amazon was $50. I will use Rodney if I need to replace the other one. Thanks!
To Headlight Pop Up Problem
