Front spring lowering bolt
Old Aug 18, 2014 | 06:51 AM
jlaw1313@comcast.net's Avatar
Default Front spring lowering bolt
I picked up a FE4 suspension (shocks, sways and springs) for my 04'coupe. The previous owner cut the bushings on the front adjusting bolts for the spring. I could use my old ones but wanted to replace them with new ones.
Does any body know if the front spring adjusting bolts can be purchased separately? Part number? Could I use the C6 style bolts? The C6 bushing looks to be slightly thinner, great for lowering, would it transfer much more road noise?
Old Aug 18, 2014 | 08:06 PM
lionelhutz's Avatar
lionelhutz
The plastic pad will wear off any of those aftermarket bolts in a fairly short period of time. If your rubber bushing are in usable condition then I'd use them.
You can only ever get them from GM with the purchase of a new spring.
Old Aug 18, 2014 | 08:52 PM
Thank you for the replies.
To Front spring lowering bolt
