Another steering wheel lock question - verify with pix
Old Aug 20, 2014 | 12:54 AM
civi's Avatar
civi
Default Another steering wheel lock question - verify with pix
So in my research on the forums, it appears that the easiest way to tell if a fix was done is to see if your steering wheel moves with the key out. Mine turns side to side with the key not in the ignition.
I also found a receipt from the prior owner that the recall was done at the dealership.
I have a 99 Coupe with the 6 sp. manual. I took a picture of the control module under the mat on the passenger side to see if the fix was done there.
Can you all take a peek and see if it looks like it has please?
If not, do I still have to worry about it and what other reason would my steering wheel still move in those directions?
Old Aug 20, 2014 | 02:53 AM
civi's Avatar
civi
Default thank you 8VETTE7
Great detail and I will check the receipt tomorrow.
Old Aug 20, 2014 | 10:45 AM
civi's Avatar
civi
Default The receipt shows it was done in 2010
So is all good do you think?
Or should I take more precautions?
Old Aug 20, 2014 | 11:25 AM
mrlmd's Avatar
mrlmd
Do you know if there's a GM site you can go to online, if you furnish a VIN, that can tell you if any recalls for this (or any other problems) have been done, or do you have to go to a dealer to find this out?
Old Aug 20, 2014 | 03:10 PM
mrlmd's Avatar
mrlmd
Originally Posted by 8VETTE7
Call the GM Customer service hot line (# located in the back of your owners manual) and have your VIN ready. They will be able to tell you if there are any open recalls but as far as I know they cannot tell you the date when they were done. As I mentioned the GM recall is NOT a permanent fix for the column lock symptoms..... Only the installation of an aftermarket solution can guarantee that you will not get stranded by the column lock system...........
What year is your car and is it a manual or automatic trans?? Makes a difference./....
I have a 2000 coupe, automatic. I am probably going to get the LMC5 one of these days, but I was just interested if anything was done to this car before I got it last year.
Old Aug 20, 2014 | 04:56 PM
civi's Avatar
civi
Default Might as well just get the LMC5
For piece of mind I guess. Just to play it safe. Thank you everyone
Old Aug 21, 2014 | 06:35 PM
mrlmd's Avatar
mrlmd
All these recent threads on here about the potential for the column lock problem - you guys are worrying the crap out of me out of getting stranded someplace I don't want to be, so, even though my car runs perfectly and I have no idea of what was done to it before to solve this problem, I just ordered the LMC5. It's cheap enough, $40 + $3 shipping to me, less than a tank of gas and worth it in every respect if it prevents that problem. Now I can't want for it to arrive so I can have some fun putting it in and tinkering with my car.
Old Aug 21, 2014 | 08:45 PM
civi's Avatar
civi
Default just bought mine via
Ebay. I did use our vendor's eBay site
To Another steering wheel lock question - verify with pix
