Help AC Problem
Old Aug 20, 2014 | 04:44 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Default Help AC Problem
I am getting hot air out of the drivers side vents and cold air on the passenger side vents. I remember a post on this a while back, but I can't find it.
Any ideas what to look for?
Old Aug 20, 2014 | 05:39 PM
65GGvert's Avatar
65GGvert
Google results:
Old Aug 20, 2014 | 05:54 PM
RedRiderZR1's Avatar
RedRiderZR1
I had the same issue once. All it needed was a re-charge. System was a little low.
Old Aug 20, 2014 | 07:30 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
+1 on Corvettes as well as many European cars; low Freon levels will cause imbalance with nothing to do with water valves. Before you worry about coolant stuff, I'd go buy a can of whatever your local parts shop has, and make sure it is the kind that comes with a gauge. Plus it up, and try the air.
Old Aug 20, 2014 | 08:02 PM
Chicago1's Avatar
Chicago1
cmon op you been here long enough to know that the search function is pretty freaking good..and this is very common
http://forums.corvetteforum.com/c5-t...side-only.html
Old Aug 22, 2014 | 05:37 PM
88redconvert's Avatar
88redconvert
Mine did that and it was low on freon. I know it doesn't sound right but it will do that.
Old Aug 22, 2014 | 11:04 PM
dmarkshark's Avatar
dmarkshark
ok, first check for any codes on the DIC? I know, that's a new one?
To Help AC Problem
