Correcting blow-by after 30#injectors/programming...
Old Jul 28, 2002 | 04:27 PM
ScreaminDemon's Avatar
ScreaminDemon
Default Correcting blow-by after 30#injectors/programming...
I've installed the SVO 30#'s with H/C and ofcourse without the right programming started getting blow-by and my car has been bellowing white smoke through the neighborhood and oil has puddled in the exh. tips. I have not driven it much. :cry . Now that I have the right programming, how long is it going to take for the rings to reseat while driving it around? Is there a possibility that they will not reseat? Should I not drive at WOT until they reseat? Thanks-David
Old Jul 28, 2002 | 09:35 PM
MelloYellow's Avatar
MelloYellow
Default Re: Correcting blow-by after 30#injectors/programming... (ScreaminDemon)
You losing any coolant?
Does the oil on the dipstick look funky?
Old Jul 29, 2002 | 12:28 AM
ScreaminDemon
Default Re: Correcting blow-by after 30#injectors/programming... (MelloYellow)
I'm not losing any coolant. The oil does look kind of funky, it may of had some fuel in it. I' just changed the oil with a 40w to see if that would fix but it started bellowing white smoke again. I did notice a slight crack at the valve guide on one of these heads before I put the H/C package in. What do I need to do, a leak down test? If it's the valve guide how do I test? Thanks-David
Old Jul 29, 2002 | 12:35 AM
CAracer's Avatar
CAracer
No joke, you need a good mechanic. Why are you putting in 40W oil?
Also, installing 30 lb injectors has nothing to do with your rings seating. :confused: :confused:
Old Jul 29, 2002 | 12:38 AM
Redline Motorsports's Avatar
Redline Motorsports
Default Re: Correcting blow-by after 30#injectors/programming... (CAracer)
30# injectors at 58 psi is a ton of fuel without programming!! It doesn't take too long to damage the cylinders with that much fuel washing the walls. Don't drive it until you get it leaned out!!
Old Jul 29, 2002 | 12:41 AM
kp's Avatar
kp
It would have taken quite a bit of fuel to wash the rings out, does the oil smell like gas? White smoke = coolent usually - or a LOT of oil. Did you by accident pour some antifreeze down the headers/exhaust when you pulled the heads? It takes a long time to burn that out.
If you look at the oil filler with the cap off with the engine running does it look like its puffing smoke out?
Is this a fresh engine? Were the old heads OK?
Was the guide itself cracked or was it cracked where it was pressed in the head?
need more nfo :)
Old Jul 29, 2002 | 12:55 AM
RHILL's Avatar
RHILL
I 2nd this
:confused: Why would you install a head that had cracked valve guides?
This is where your problems are your cracked or worn out valve guides have worn out your valve guide seals.
Old Jul 29, 2002 | 01:07 AM
ScreaminDemon
Default Re: Correcting blow-by after 30#injectors/programming... (kp)
The oil did smell alittle like gas. The head did have a tiny fracture where the guide was pressed into it. I put about 50 miles on it without having the injectors programmed , just to get it home. No antifreeze in exhausts. I put 40w in to see if that would reseat the rings if that was the problem, since 30w is so much thinner and I'm sure by now mixed with so much gas. When everything is right I'm going to run a 50w. You can do that when you run a huge solid cam. The oil is mixing with the fuel, if it was water it would look like milk, but it's just looking thinner. What do I do next to test?
Old Jul 29, 2002 | 01:34 AM
kp's Avatar
kp
You need to make sure the programming is correct and I think you need to talk to ARE. Seriously, something is very wrong. The oil will look milky if there is water in it but sometimes you wont see it until you drain the oil. If you washed out the rings or hurt the moly on them they will never seal right.
Not to be a jerk but I thought you were joking when I first read this - you really need to talk to whoever built the short block.
Old Jul 29, 2002 | 01:37 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Where are your fuel trims at non WOT, and where are your O2 sensors at WOT? I've seen many C5's with 30# SVO injectors, including my 2000, and the PCM is able to adjust for them, at least at non-wot to 14.7:1 a/f ratio by skewing the trims way negative. If they went out of thier range to compensate you would set a code. Of course you really need to get programming, or MAFT to adjust properly for WOT.
[Modified by kewlbrz, 11:51 PM 7/28/2002]
Old Jul 29, 2002 | 01:48 AM
ScreaminDemon
I just drained the oil tonight and installed a new filter, and the oil feels and smells like it's mixed with alittle fuel. We only installed a solid roller H/C package with a few other bolt ons, I still have a stock bottom end, I think the rings should have a good chance of reseating if the programming is right now and the use of a thicker oil. Nevrenuf did my programming, and I do believe it is correct. I just want to know how to find out (test) for blow-by or if it's the valve guide? I have IM ARE, and I'll call them in the morning. I wonder if a fractured valve guide seat can be repaired???????? :confused:
Old Jul 29, 2002 | 01:59 AM
ScreaminDemon
Default Re: Correcting blow-by after 30#injectors/programming... (kewlbrz)
Shawn, Tom (Nevrenuf) did say he needed to know where my trims were after he did my programming. Is it possible that this bellowing white smoke could just be that I need more programming in my fuel trims? If I Autotap it what all do I need to be looking at???? Thanks
David
Old Jul 29, 2002 | 02:14 AM
kp's Avatar
kp
The valve guide thing may be no big deal depending on where it is cracked. A bad valve guide will smoke and draw some oil into one cylinder if its intake and will blow some oil out the exhaust if its the exhaust guide.
It sounds like you have a little more problems then one valve guide. There are few things that can go wrong on a h/c install. If you have access to a compression or leakdown tester you could check the rings. You could also look at the plugs to see if they all look the same or if you have a couple problem cylinders.
Old Jul 29, 2002 | 02:23 AM
ScreaminDemon
Can you see from my pic how my air/pressure lines are run? I have a 3/8th's hose running from the intake to the right valve cover with a filter on the other side, and the TB tube is capped. I was told this could be pulling too much air into the cylinders and oil with it? :confused:
Old Jul 29, 2002 | 02:29 AM
2001C5's Avatar
2001C5
you mean this picture...
Old Jul 29, 2002 | 02:35 AM
kp's Avatar
kp
depends if there is a baffle under where the PCV is or not, not would be bad. Unplug the line from the intake and cap it off and see, it wont hurt to run it w/o the PCV for a few minutes. You can also see how much blowby it has then by looking how much is puffing out of the pcv hole..
BTW, you may have some problems with the way the PCV is hooked up there. The stock setup is hooked to the top of the TB so the air that is drawn into the PCV system is metered by MAF. the way you have it the air is drawn from outside and it will screw with the a/f, most likely an idle surge or minor tuning issues. Or maybe it will work OK, never tried it :)
[Modified by kp, 12:48 AM 7/29/2002]
Old Jul 29, 2002 | 03:06 AM
ScreaminDemon
The pcv has a baffle, and the hose is hooked up to the intake behind the TB. It's the same air metered by the maf. Are you saying the air tube at the TB is metered smaller than at the intake? :confused:
By the way, nice pic Kerry!
Old Jul 29, 2002 | 03:11 AM
kp's Avatar
kp
If the air is drawn in through the breather on the valve cover it is unmetered. The line thats capped off on top of the TB is where the stock PCV system draws its air from, there are no breathers on the valve covers on a closed system. The air is pulled in through the air filter and MAF. The way it is now it acts like a giant vacuum leak. The PCV is connected to the right place. Thats not what is making it smoke though, pull that PCV hose and see if its full of oil.
2am I'm goin to bed - good luck :)
[Modified by kp, 1:18 AM 7/29/2002]
Old Jul 29, 2002 | 03:22 AM
ScreaminDemon
Thanks kp, the airline does have a little oil in it, it does not puff any smoke. I'll talk more with ARE in the morning, but I was told this setup was fine...
To Correcting blow-by after 30#injectors/programming...
