air conditioner
Old Aug 31, 2014 | 06:00 PM
Michael Pass's Avatar
Michael Pass
5th Gear
Default air conditioner
Blows cold air out on passenger side and hot air on driver's side! Working fine until Saturday when i stopped at red light. The motor shut off and a message said take key out for 10 seconds. So i did and the motor started and that's when the problem started! Weird!!!
Old Aug 31, 2014 | 06:40 PM
Chicago1's Avatar
Chicago1
My man I know you are new here but the search function works wonders here. Some of these topics have been pulverized..Hell you can do a google search and 10 topics show up but this should help.
https://www.corvetteforum.com/forums...1a147a9f73d5e8
And for the newbies...Check the sticky on top..And welcome
https://www.corvetteforum.com/forums...must-read.html
Old Sep 2, 2014 | 04:17 PM
RedZMonte's Avatar
RedZMonte
either a problem with the air blend door not moving or the R134 is low. my bonneville would blow hot on drivers and cold on passengers, topped off the R134 and blows cold on both sides again.
S
Old Sep 2, 2014 | 05:17 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
Before you pull your hair out diagnosing or pay the stealer, go buy a can of (brand of your choice) A/C recharge with lube (the one with the hose and gauge) for about $35. Very common issue with low freon; the system kind of starts limping, cold through 1 side but not the other.
To air conditioner
