Head Unit Install
I am installing a new sound system in my 99 frc and have run into a problem.. I am trying to hook up my illumination wire and the aftermarket wiring harness is pretty much useless only thing I can use it for is my memory power.. the illumination wire is dead..so is the 12v keyed .....have heard that you can tap into the climate control illumination..I have found an illustration on the digital control..
But I have the Manual Climate Control System..does anyone have any idea what wire it is on the Manual system..or what wire I can tap into or what voltage the wire is so I can track it down...Thanx in advance.. will post pics of the system when done..
Clarion nz-500 head unit
Zapco competition Amp
Hertz Mille Components
MB Quart Sub...
If you just want to power the radio illumination when the ignition is on I have another idea but my info is at home.
