C5 Rattle Sound After Reving Engine
Old Sep 14, 2014 | 01:41 AM
NJD's Avatar
NJD
Default C5 Rattle Sound After Reving Engine
I notice while stepping on the acceleration while in park, I hear a rattling sound. Can someone help?
Old Sep 14, 2014 | 01:01 PM
BlueDragon's Avatar
BlueDragon
Need some more info! Could be anything from timing chain to a bad belt tensioner, was the AC off? Or a bad belt. You said in park so I assume it is a stomp and steer (LOL)
Old Sep 18, 2014 | 06:39 PM
NJD's Avatar
NJD
It's a bad Catalytic converter. I'm having both replaced w/CATCO CONVERTER. MAGNAFLW doesn't have them for my 02.
Old Sep 18, 2014 | 09:35 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
If your car is stock, with stock tune, I would get a low mileage take off factory Hpipe. Aftermarket catalyst rarely keep the check engine light off for more than 6,000 miles. P0420-430 will almost always set.
Old Sep 18, 2014 | 11:29 PM
NJD's Avatar
NJD
A bit late. I've had the Catco installed. I'll have to keep a watch on that. Hope that won't be the case. Thanks for the response. By the way, what are those codes?
Old Sep 19, 2014 | 06:34 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
P0420 catalyst efficiency bank 1
P0430 catalyst efficiency bank 2
You could pay a tuner to delete the codes.
To C5 Rattle Sound After Reving Engine
