224 cam in a 427 CI motor? wow thats what most stock CI motors use. I have a 230/227 cam in my a4 stock CI fbody and have no drivability issues; its all about the tuning! ;) , but anyway those are some nice numbers, but throw a slightly bigger cam in and you'll some nice 500+ figures!
I went through 5 months of tuning with the 229/114 cam and HATED IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Too much mirror and cockpit shake and stalling. The dyno overlay curves also show that the 224 cam crushes the 229 cam until about 5500rpms when the 229 has a power peak of about 15hp more around 6200 or 6500--it never catches up in torque. I had BOTH cams in my car. However, each to his own; some like lots of rumble and shake and the 229 cam does have more peak power.
What’s the rest of your setup like?
<LI>LS1/LS6 heads?
<LI>What kind of headers?
<LI>Cats/Off road?
<LI>What kind of exhaust?
<LI>Pump gas I’m assuming….
When I get an email of the dyno graph I will send it to you so you can post it as I do not know how.
Some more pieces of the puzzle: stock LS6 intake; ported and polished stock throttle body from Halltech; Blackwing; 160 degree TSTAT; DRM 1 3/4" headers; hollowed out, failed Viper cats; 3" custom exhaust through Corsa Touring mufflers (quiet on cruise with no resonance and NASCAR on WOT); terrible California 91 pump gas.
We know we are leaving a bit of power on the table with: (a) the headers have a 2 1/2" collector going into a 3" exhaust; (b) no use of "merge collectors"; and (c) Corsa Mufflers (DynoMax add about 5hp or more but have resonance).
Remember? I rode in your in beast when all you had was the measly LS6 ;) , and I thought it pulled like a freight train. All I can say is, with this 427, you must be having some serious traction problems, burned clutches and or shattered rearends. :smash:.
Congrats on a succesful build (unless my suspicions are correct!) ;)
Mako, that's cam sounds very much the same as my first cam in my 427. I ran it with 1.8 rockers though.. IMHO its better than the larger cams I've tried 4 so far.. Idles like a stock car and runs 10's all day long.. I dislike the race car lope ect.. Who cares if you can get it to idle!
