Hard power steering
Old Sep 25, 2014 | 10:32 PM
baildvetter000's Avatar
baildvetter000
Default Hard power steering
I pulled the rack to replace the front timing cover seal. Put everything back together and drove it around 5 miles and everything was fine ( car is a 98 vette). After sitting around an hour got in it and no power steering at idle. Rev it up a little and steering is fine. Pretty sure all of the air is out. Went out this evening after it cooled off and steering was fine. After about a 3 mile warm-up steering got hard again. Pump is quiet-no noises. It worked perfect till we took the rack off and put it back on. Could we have got some dirt in the system? I have owned 7 Vettes in my lifetime but never a C5. I am beginning to regret buying one. The car does have a lot of miles-94K.
Old Sep 25, 2014 | 10:48 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
94k is not a lot for a c5 if it's been maintained properly. What kind of fluid did you put back in?
Old Sep 26, 2014 | 08:14 AM
baildvetter000
Just regular generic PS fluid. Is that wrong?
Old Sep 26, 2014 | 08:21 AM
dadaroo's Avatar
dadaroo
I think you need to bleed it again. How did you do your bleed?
Old Sep 26, 2014 | 08:25 AM
dadaroo's Avatar
dadaroo
Here is a link to review:
https://www.corvetteforum.com/forums...post1586217937
Old Sep 26, 2014 | 05:37 PM
baildvetter000
My friend had some kind of vacuum set-up where he hooked an air connection to the opening on the reservoir.
To Hard power steering
