detonation on my 2000
Old Jul 30, 2002 | 05:31 PM
snake killer's Avatar
snake killer
Default detonation on my 2000
I have a friend that has a 2000 coupe and it has detonation. He took it to the gm garage and they said it was common in 2000's. has anyone else had this problem? They said gm is coming out with a fix soon (probably a new chip). He has not talked to anyone else with this problem.
I think they are bsing him.
Old Jul 31, 2002 | 12:12 AM
enloe's Avatar
enloe
Default Re: detonation on my 2000 (snake killer)
I just bought my 2000 C5 and it was detonating bad under light throttle. I reset the PCM after learning about it on this site. The car immediately ran better and the detonation was completely gone. The car is alot more responsive too. Since then I have installed a Donaldson filter and I still don't have any detonation.
Old Jul 31, 2002 | 01:07 AM
Xssesive's Avatar
Xssesive
Default Re: detonation on my 2000 (enloe)
How did you reset PCM? :rolleyes:
Old Jul 31, 2002 | 12:16 PM
carpe dm's Avatar
carpe dm
Is it a six-speed? If so, you can recommend the pvc fix mentioned in a post above. You can simply disconnect the neg.bat. terminal for a few minutes to allow the pcm to "forget" some old, bad habits. :D What type of air intake/filter does it have. Is the MAF screen still in? May be running lean.
[Modified by carpe dm, 10:18 AM 7/31/2002]
Old Jul 31, 2002 | 01:05 PM
GR8-LIFE's Avatar
GR8-LIFE
eeek! First oil, now detonation? Aren't problems suppose to go away with each year instead of new ones occuring?
Old Aug 9, 2002 | 10:48 PM
Xssesive's Avatar
Xssesive
snake killer need to check this article out about detonation: http://www.fbody.com/members/stevenm...ML/pcv_mod.htm :yesnod:
Old Aug 10, 2002 | 05:00 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
I have had the problem after changing the cam at wide open throttle. Tuning should take car of the problem, soon I hope. :)
[Modified by wallstAL, 1:01 AM 8/10/2002]
To detonation on my 2000
