Ball joint question
Old Sep 26, 2014 | 01:47 PM
911AXER's Avatar
911AXER
Default Ball joint question
Just wondering if anyone can help. I need to replace my front and rear ball joints on my 2003 Z06. My research says a good way to go is Moog K6537 Upper and Raybestos 5001128 lower. MY question is are the front and rear ball joints the same? I can only find listings for front.
Thanks!
Old Sep 26, 2014 | 06:35 PM
911AXER's Avatar
911AXER
Default Ball Joint question 2
Thanks!
They say if you ask yourself a question and answer it yourself you may be crazy. Well here goes. After further research and examination of both front and rear spindles the upper and lower ball joints for the front and rear are identical.
Old Sep 26, 2014 | 11:48 PM
SG Lou's Avatar
SG Lou
yes they are....I replace both upper and lower on all 4 corners on my 04.
Do yourself a favor...put your ball joints in the freezer the night before your gonna do the job. The cold will cause the metal to shrink....I know it sounds silly but it works. I used a Hydraulic Press and a ball joint press and they went in with little effort.
Old Nov 1, 2014 | 06:05 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I have a 97 c5 and the lower ball joints are bigger then the upper ball joints,How are they the same?
Old Nov 1, 2014 | 06:55 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
They are referring to front and rear lowers being the same, uppers as well.
Old Nov 1, 2014 | 09:04 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
and you can put the front brake calipers and rotors on the rear as well. you just lose your ebrake.
Old Nov 1, 2014 | 11:59 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
If your ball joints are worn it may be a good time to replace the inner/outer tie rods for the rear. 70k+ miles they are on borrowed time.
Old Nov 2, 2014 | 04:21 AM
SG Lou's Avatar
SG Lou
Old Nov 2, 2014 | 08:56 AM
4horseman's Avatar
4horseman
Thanks!
Front upper is ACDELCO Part # 45D0128
front lower is ACDELCO Part # 45D2339
Def different.
But if you are referring to front and rears they are the same.
Hope this helps
Old Nov 2, 2014 | 09:34 AM
SG Lou's Avatar
SG Lou
Moog and Raybestos Pro....you won't go wrong.
They have grease fittings....ACDelco does not
Old Nov 19, 2014 | 12:11 AM
KoreaJon's Avatar
KoreaJon
Weeeellll......almost. See my new thread here:
https://www.corvetteforum.com/forums...post1588295507
Regards,
KoreaJon
Old Nov 19, 2014 | 08:23 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
Regards,
KoreaJon
In your scenario you are using rear rotors from a Z51. Nice upgrade and get to retain the ebrake.
Old Nov 19, 2014 | 04:40 PM
Reese2099's Avatar
Reese2099
2nd Gear
Hey guys, I have. 2001 c5 base... Are you guys sure that the rear upper and front upper ball joints are he same?
To Ball joint question
