I just got my Blackwing, but didnt get any instructions....I got everything out of the car ...and all the new stuff where i think it goes....but where the heck does that little rubber coupler go? Thanks
Re: Blackwing Install Question (OHoneC5)
The little coupler is for 2001 and newer Vettes. I just put the Blackwing on my 2000 and it was a very straightforward install. The only hard part was getting the clamp off the MAF sensor - it is crimped from the factory. Be sure you line up the Blackwing with the tabs on the MAF and you will be set. Also, be sure you tighten down the clamps well so that there is no air leaks.
