Vararam intake install ??
Old Sep 26, 2014 | 05:29 PM
King Lear's Avatar
King Lear
Veteran
Default Vararam intake install ?? Vacuum PCV?
I have a 97 everything is hooked up that plugged in except for the little vacuum hose that went into the accordion housing. What did u guys do with it? Leave it open? plug it? or put a hole in the power duct hose and use it? I called Vararam and I get is an answering machine all day with no return call.
Old Sep 26, 2014 | 11:56 PM
King Lear's Avatar
King Lear
Veteran
Anyone?
Old Sep 27, 2014 | 07:19 AM
NukeC5's Avatar
NukeC5
Drill a hole and place the vacuum tube there. That's the way the early models (97/98) are meant to function.
Old Sep 27, 2014 | 08:47 AM
King Lear's Avatar
King Lear
Veteran
Thank you much, That is what I figured but I just wanted confirmation before I did it. Its always easier to drill a hole later then to try and plug one after!
Old Sep 27, 2014 | 08:59 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I capped mine off, just like in your first pic.
To Vararam intake install ??
