Need help guys
Old Sep 28, 2014 | 12:10 AM
Blow Torch's Avatar
Blow Torch
Default Need help guys
I replaced my ailing transmission with a rebuilt, updated RPM trans today.
When I went to fire it up to add fluid, it ran for about 30 secs and shut off. try repeatedly to crank it, but it would fire and shut off every time.
Codes were
107
705
706
and a couple of other random ones.
It always gave me a "service engine soon
Everytime I clear the codes, 107 ALWAYS came back. Even without trying to crank the car, it would immediatly reset after clearing.
I have a FAST, so I can see the MAP and it is plugged in and (although loose as they all are) it is in the manifold.
Do you think I am looking at a bad MAP, or is it more complicated? Just seems odd that I didn't touch it, and it started giving issues after working on the TRANS.....
BTW, I am SD tuned, no MAF
Old Sep 30, 2014 | 09:28 AM
Blow Torch's Avatar
Blow Torch
Update
Note; the car is approx. 3hrs away, so trying to do some research before making the trip back
Although "someone" forgot the paper with the codes, I THINK one of them was 1635. The P1635 code is set when the reference voltage from the sensor is out of range. It gets 5 volt readings from the TPS, EGR, MAP and a couple others. Since it also gave a code for 107 (MAP sensor) I can only hope that the MAP is bad and it is NOT sending back the “reference voltage” to the PCM.
I have ordered a GM MAP.
Old Sep 30, 2014 | 10:33 AM
StingrayRebel's Avatar
StingrayRebel
did you disconnect the battery?... I'm sd tuned as well and when I disconnect the battery and start the car for the first time after reconnecting it the car will run like crap and sometimes die until the maf fails then it runs perfect... on one occasion it took probably 10-15 tries before the maf failed... it could just be the way mine is tuned though
Old Oct 1, 2014 | 10:14 AM
Blow Torch's Avatar
Blow Torch
I had the battery disconnected while I swapped the trans. I unhook the battery anytime I do any major work, and have never had an issue before.
Brett gave me some volt readings to check, but the car is at a buddys house because he has a two post lift. Makes it difficult to diagnose.
Old Apr 14, 2015 | 10:01 PM
1slowride's Avatar
1slowride
Default Find?
Blow Torch
What did you end up finding wrong with the car? I did the same trans pull and now have the No Start as well with the same P1635 code.
To Need help guys
