power seat help needed
Old Oct 4, 2014 | 11:13 AM
dmarkshark's Avatar
dmarkshark
Default power seat help needed
Has anyone had their power seat motors go out?
My drivers side stopped working, fortunately in a spot where I can drive it just fine. The telescopic feature also stopped, I know this is also tied into the SCM. I have three codes BO846 HC, and BO856HC and B2857 HC,
Manual says to scan, but that is not an option. I could take it in, but think it my be cheaper to get one on Ebay or someplace and trade it out. What do you guys think?
Old Oct 4, 2014 | 11:32 AM
dadaroo's Avatar
dadaroo
Not at home with the FSM but did a search that suggested it may be a wiring or connector issue. I would look there first. Will get back later. Not common but have seen connector issues before under the seat.
Old Oct 4, 2014 | 12:07 PM
dmarkshark's Avatar
dmarkshark
Thanks Dadaroo, I should also mention when it stopped I checked the fuse under the passenger compartment, and it was extremely hot. Also, I do have power on the lumbar support.
Old Oct 5, 2014 | 09:45 AM
dadaroo's Avatar
dadaroo
Fuse or Circuit Breaker 35? Are you having a battery drain issue also?
B0846 SCM Memory voltage problem
B0856 Telescoping Column position sensor issue
B02857 Telescoping Column Out Switch shorted to ground
Old Oct 5, 2014 | 12:44 PM
dmarkshark's Avatar
dmarkshark
Circuit breaker 35. I switched the two seat circuit breakers to make sure, and both worked fine on the passenger seat. No battery drain.
The car was fine until I went to move the seat up and forward, and it slowed to a stop , followed with the dash light show. I checked the seat switch with the passenger one and it was fine. There is power as the lumbar works fine. I doubt all three motors stopped at the same time, but? I wonder if when I moved the seat the threaded (not sure what the actual name is) rods jammed up, thus drawing too much on the electronics, thus the hot CB? The seat has a broken plastic piece on one of the seat movement rods that I pieced together with a hose clamp, but its been on a while and no problems. But, I have never just raised the seat up and forward like that before either as I was looking for a small article under the seat.
To power seat help needed
