Trouble starting
Old Oct 5, 2014 | 08:26 PM
cgallagher04's Avatar
cgallagher04
Default Trouble starting
So my 2001 corvette has trouble starting on the first and sometimes second and third time, with that being said I have a cam position sensor low voltage check engine code. I replaced the cam position sensor when I did my cam swap, but it still has the same problem and same code. Does anyone have any idea what is wrong and what I could try to fix it? Thanks in advance for any help.
Old Oct 7, 2014 | 08:53 PM
cgallagher04
So the dealer said they think it is the fuel pump going out, went to dyno my car on sunday and bam the fuel pump is losing pressure at around 4k rpms and killing my afr. So new fuel system it is.
