Horn Won't Work
Old Oct 6, 2014 | 07:11 PM
bartsky's Avatar
bartsky
Default Horn Won't Work
I just got a 2004 Z06 in and the horn will not blow. You can hear the relay under the hood clicking. Any thoughts??
Old Oct 6, 2014 | 07:25 PM
65GGvert's Avatar
65GGvert
Bad contact in relay
Two bad horns (stuck or open)
Broken wire
Ground loose or corroded on horns
I'd put 12v on the horn wire. If the blow, the horns, ground, and wire from that point are good. You could also have someone hold the horn button down and tap on the relay to see if you could get a sound out of the horn. If so, change the relay. A more civilized way would be to measure for 12v coming out on the relay wire to the horns when the button is pushed.
If applying 12v to the horn gets no sound, connect a wire to a known good ground and touch the horn housing with it. If it blows, bad ground connection.
Old Oct 6, 2014 | 07:33 PM
bartsky's Avatar
bartsky
This car has a procharger installed with I guess intercoolers up front. I'm thinking maybe they unhooked horns?? If they were unplugged, would the relay still click. I tried several like relays.
Old Oct 6, 2014 | 07:39 PM
old stingray's Avatar
old stingray
Yes
Old Oct 6, 2014 | 07:53 PM
bartsky's Avatar
bartsky
Originally Posted by old stingray
Yes
Horns are up in the nose right? One side?
Old Oct 6, 2014 | 10:25 PM
bartsky's Avatar
bartsky
Is there another horn relay besides the one in the underhood fusebock?
Old Oct 7, 2014 | 07:48 AM
65GGvert's Avatar
65GGvert
Originally Posted by 8VETTE7
If there is not one shown in the above wiring diagram then there is nothing additional that came from the factory.
Have you checked fuse 11 under the hood (shown in 8vette7's diagram)? IF it's good, check the other stuff I gave you above.
Old Oct 7, 2014 | 09:57 AM
bjones7131's Avatar
bjones7131
When I bought my vette and on the drive home (3hrs) my horn wouldn't work and after many attempts on pushing on the horn location it finally started working, taught me a lesson to try every button option on a car before u puchase. I think car had been setting and used on a daily/weekly basis. works fine now, maybe a stuck relay ????????
Old Oct 7, 2014 | 10:12 AM
bjones7131's Avatar
bjones7131
I know, sorry I was talking about my vette, sorry should have been clearer
Old Oct 12, 2014 | 06:31 PM
bartsky's Avatar
bartsky
Well I reached my hand down through hood by headlight, and wiggled the horn connector. I then hit the panic button on the fob. The horns fired, but sounded awful then quit. I can make them work a lil, then they quit. I blew out the horns and connections with duster can. Should I just buy a new set of horns??
Old Oct 12, 2014 | 07:05 PM
bartsky's Avatar
bartsky
Do the horns have to be bolted to car, or just horns in hand? Connect 12v to one blade in connector, and ground to other blade?
Old Oct 12, 2014 | 07:06 PM
bartsky's Avatar
bartsky
Btw my horns were mounted in an incorrect upward position, so maybe water ruined them??
Old Oct 12, 2014 | 08:17 PM
bartsky's Avatar
bartsky
Ok thank you. I will check them tomorrow with some alligator clips and a battery. I think maybe they installed some wrong from the factory.
Old Oct 13, 2014 | 03:59 PM
bartsky's Avatar
bartsky
I installed new horns from Chevy today. Works perfect. One of my old horns would not work at all, the other tried. They sell you a high and a low note horn. I transferred bracket and harness from old horn set...
Old Oct 13, 2014 | 06:09 PM
bartsky's Avatar
bartsky
I sure did...
To Horn Won't Work
