Traction control and ABS
Old Oct 8, 2014 | 09:12 PM
71corv's Avatar
71corv
St. Jude Donor '08
Default Traction control and ABS
To add to this discussion I am having the same problem with the TC light and the ABS light showing on the dash. The codes I get are:
10-P1571 H C
58-U1040 H C
60-U1040 H C
I have cleaned the grounds under the hood, disconnected the battery, and reset the DIC and the codes continue to come back. Not sure what is going on. Any ideas? Thanks,
Gene
Old Oct 9, 2014 | 08:40 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
https://www.corvetteforum.com/forums...ed-torque.html
Old Oct 9, 2014 | 12:57 PM
zachaeous's Avatar
zachaeous
Default abs traction control
10-P1571 H C
58-U1040 H C
60-U1040 H C
Gene
I went through this after purchasing my 2001 coupe. PO had rebuilt the EBCM unit, replacing the relay and soldering connections for a positive connection. Still would get traction control lights and same codes as you. After searching the forum I found the ignition switch post by Bill Curlee and removed my ignition switch and cleaned the contacts as per the instructions provided and no more abs and traction control lights or codes. It was that easy, hope this helps you.
https://www.corvetteforum.com/forums...ch-repair.html
Old Oct 9, 2014 | 08:59 PM
71corv's Avatar
71corv
St. Jude Donor '08
Thanks for the info mrr23 and zachaeous. Some how I missed the post on the 1571 reset. Will look into that.
Gene
To Traction control and ABS
