Code P1133 Oxygen sensor?
Old Oct 9, 2014 | 11:20 PM
1998BlackPlasticToy's Avatar
1998BlackPlasticToy
Default Code P1133 Oxygen sensor?
Check engine light was on. Had the shop pull the codes. Getting P1133. Says to replace Oxygen sensor, bank one.
OK. Which side is that? I just had them installed a few months ago. I'm sure they are under warranty. But which one do I replace?
Old Oct 10, 2014 | 07:43 AM
dadaroo's Avatar
dadaroo
Driver side forward of the cat. Would look for a wiring/connector issue first.
Do you not know how to pull the codes from your dash?
Old Oct 10, 2014 | 01:03 PM
1998BlackPlasticToy
[QUOTE=dadaroo;1588011617]Driver side forward of the cat. Would look for a wiring/connector issue first.
Do you not know how to pull the codes from your dash?]
I DO, thank you. Car was at the shop getting shocks installed. Doesn't do me personally any good to read the codes. I'm no longer able to do much of the work.
To Code P1133 Oxygen sensor?
