help clutch issue...
Old Oct 10, 2014 | 12:40 PM
Racinjace22's Avatar
Racinjace22
Default help clutch issue...
I have an 02 Z06 with a clutch issue.... If I run the car hard the clutch sticks down and feels like it pulses. I then have to put my foot under the pedal and lift it up. NOTE: it only does this when its warm and running hard. cold it wont nor if i drive normal.. it also pulses when its warm and i press in the clutch and rev it up high a few times. Could this be just that i newed to change the fluid? its an 02 and everything is stock. thanks
Old Oct 10, 2014 | 03:47 PM
john8642's Avatar
john8642
Changing the fluid and checking the shifter adjustment are the cheapest and easiest things to start with. The slave cylinder on 97-03 cars is a poor design that was improved for the 2004 model, so if the first two steps don't work it may be time for a new clutch and slave cylinder.
Old Oct 10, 2014 | 04:30 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I suggest reading Ranger's method. https://www.corvetteforum.com/forums...al-issues.html
Heat is detrimental to the clutch fluid, so frequent dilution or replacement is often needed. I personally have installed a remote clutch bleeder from Tick Performance to aid in the process. The remove bleeder also makes it a cleaner process. Frequent changes of the clutch fluid should help.
Old Oct 10, 2014 | 06:14 PM
Racinjace22
thanks guys!
To help clutch issue...
