Driving Lights Adjustable??
Old Jul 31, 2002 | 06:09 PM
Arthur6's Avatar
Arthur6
Default Driving Lights Adjustable??
Guys, are the fog/driving lights adjustable? Mine seem to point way down low. Anyone?? Thanks, ART
Old Jul 31, 2002 | 07:09 PM
chocoholic's Avatar
chocoholic
Default Re: Driving Lights Adjustable?? (Arthur6)
Get thee a Torx T15 screwdriver applied to the little adjusting screw which is outboard of the lamp itself. Lie on the floor facing the car and you'll see the place to do it.
Generally, many people report that four clockwise turns brings the fog lamps up where they would like them. They are fog lamps though, not driving lamps.
If you search around you'll find some pictures and more detailed descriptions.
Old Jul 31, 2002 | 09:46 PM
Xssesive's Avatar
Xssesive
Default Re: Driving Lights Adjustable?? (chocoholic)
Replace the stock bulb with Sylvania 885's the 50W bulb much brighter than stocker. Same connector. I use mine for Driving lights when the sun goes down, they look COOL! :cool:
Old Jul 31, 2002 | 10:56 PM
Vetts Forever's Avatar
Vetts Forever
First, there is no horizontal (side to side) adjustment. You can only go up & down.
The small round hole in the front of the fog light shroud is where you place your torx driver (or allen wrench) to adjust the fog light.
Place the car on a level surface approx. 25 ft away from a taget screen (blank surface). Adjust the fog lamp up or down until the top edge of the high intensity zone on the screen is 4 in below the hoizontal centerline of the vehicle.
:cheers:
To Driving Lights Adjustable??
