Vortech V2 oil pressure?
Old Oct 21, 2014 | 02:42 PM
Terryreimer's Avatar
Terryreimer
Cruising
Default Vortech V2 oil pressure?
I have a 99 Frc with 6.0 prc heads,blower cam,yella terra rockers,vortech V2 blower etc....just installed all new gaskets including head gaskets,lifters...my oil pressure under wot stays at around 35-40psi upto 6800 Rpms...sometimes coming down to idle it's around 12-18psi...do I have a problem or is this ok? It has a LPE ported oil pump,car runs fine with no noise
Old Oct 21, 2014 | 10:13 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
I would say that's a big problem if it's accurate. What oil are you using? I suggest getting a good mechanical gauge on it and recheck it. If it's still low, I would send an oil sample out for testing. If the report is ok, replace the oil pump. Otherwise pull the engine for tear down before it grenades.
Old Oct 22, 2014 | 01:14 AM
C5Natie's Avatar
C5Natie
I agree those pressures are quite low which can indicate a serious issue. Verifying the pressure with a mechanical gauge is a must. With my V2-si I see at least 60psi or more at wot and a hot idle pressure of 38-40psi
To Vortech V2 oil pressure?
