Best Plug Wires????
Old Aug 1, 2002 | 10:40 AM
Gramps's Avatar
Gramps
Default Best Plug Wires????
Just did heads, cam, intake, clutch, etc on '99FRC. They put in new plugs, but did not replace wires. What is the best upgrade/ direct replacement (i.e. no cutting and terminating) out there, and where?
Old Aug 1, 2002 | 11:08 AM
RyanC7's Avatar
RyanC7
Default Re: Best Plug Wires???? (Gramps)
I went MSD, no radio noise.
Old Aug 1, 2002 | 11:16 AM
blackjack's Avatar
blackjack
Default Re: Best Plug Wires???? (Ryan2002C5)
I've had the GM performance plug wires on for a year. They work fine and fit perfectly.
-Blackjack :flag
Old Aug 1, 2002 | 11:23 AM
Chris@SD's Avatar
Chris@SD
THe stock wires are very good. Unless you are having a problem with these, I would stick with them. If you are having a problem, the MSD wires are great!
We do have them in stock if you need them. (not on website yet)
Thanks,
Old Aug 1, 2002 | 11:24 AM
carpe dm's Avatar
carpe dm
:D :yesnod:
Old Aug 1, 2002 | 01:08 PM
Crushinator's Avatar
Crushinator
Default Re: Best Plug Wires???? (Buckmaster)
I have MSD's as well and really like them. They look great!
[Modified by QuickSilver97, 12:08 PM 8/1/2002]
Old Aug 1, 2002 | 02:06 PM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Best Plug Wires???? (QuickSilver97)
I run Magnecor wires. You really will not notice much if any difference in plug wires, but the Magnecors do offer the best windings/inch.
Old Aug 1, 2002 | 05:35 PM
ace's Avatar
ace
I am using the MSD 8.5 mm wires and they appear to be working great. With the TR55 plugs and MSD wires my car does idle better :D
Exact same setup as me, I feel my car idled better also. :jester
Old Aug 6, 2002 | 10:00 PM
Chalky's Avatar
Chalky
St. Jude Donor '08-'09-'10
I have used a MSD. Still have them in a box.
Worked fine.
Old Aug 6, 2002 | 10:17 PM
Xssesive's Avatar
Xssesive
Default Re: Best Plug Wires???? (Chalky)
Have to go with the Magnecor"s :yesnod: :yesnod:
[Modified by Xssesive, 12:37 AM 8/7/2002] :yesnod:
[Modified by Xssesive, 12:40 AM 8/7/2002]
Old Aug 7, 2002 | 12:48 AM
kewlbrz's Avatar
kewlbrz
Cruise-In III Veteran
If your wires are worn, or your using headers or you want the looks, in any case, I have really loved the magnecor KV85. It is a superior constructed wire. I have used all kinds.
To Best Plug Wires????
