How long for wait before opening hot radiator drain ?
Old Oct 26, 2014 | 04:53 PM
flyingillini's Avatar
flyingillini
Default How long for wait before opening hot radiator drain ?
I am flushing my C5 coolant. How long should it take for a hot car to cool so that its safe to open the surge tank and radiator draincock ? Thanks guys.
Old Oct 26, 2014 | 08:16 PM
CaliforniaJack's Avatar
CaliforniaJack
Default Like many things in life, It Depends
The pressure cap allows coolant (half dexcool and half distilled water) to NOT boil until over 230 F (at sea level). You could be SCALDED if you attempt to 1/2 turn (NOT completely open) the radiator cap within 10 minutes of a boil over. Wait until the hissing stops before carefully open the Pressure cap the rest of the way.
Old Oct 28, 2014 | 07:03 AM
Cybermind's Avatar
Cybermind
I agree with comments above. The design of the radiator overflow cap keeps you pretty safe as long as you open it very slowly allowing for the air pressure to escape before you open it completely. Just make sure you put a rag over it when doing it.
Old Oct 28, 2014 | 10:46 AM
dadaroo's Avatar
dadaroo
For normal flushing I would wait 30 minutes and like he said use a towel or thick rag on the cap to release the tank pressure. ! hour if you had a boil over issue of some type. When I flush my car systems I just do it over several days and drain and refill in the morning when I know everything is cold.
Safety first, you are not on the side of the road trying to get home. I also have safety glasses in all my cars in case of an emergency. I have had to refill at least one car on the side of the road. Suggest you use a pair if you are doing your work hot.
Old Oct 28, 2014 | 02:33 PM
3boystoys's Avatar
3boystoys
When hoses are cool to the touch.
Old Oct 28, 2014 | 03:02 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Good answer!!
Old Nov 29, 2014 | 09:02 PM
Stellabarbara's Avatar
Stellabarbara
Stellabarbara
2015 C4 of Year Finalist
Default Can't get radiator cap off
Is there a certain way to get the radiator cap off? Maybe I am doing something wrong... Any suggestions would help.... Thanks
Old Nov 29, 2014 | 10:35 PM
Voodoo13's Avatar
Voodoo13
Lefty loosy, right tighty. Sorry, I couldn't help myself!
Really though, press down and turn, it should come off.
Old Nov 29, 2014 | 10:38 PM
StingrayRebel's Avatar
StingrayRebel
you can do it while still warm if you loosen the radiator drain plug first, that will release the pressure in the system and then you can remove the cap... just use common sense while draining it and you will be fine, meaning don't stick your face right in front of the drain plug while loosening it
Old Nov 30, 2014 | 06:38 PM
Stellabarbara
Stellabarbara
Default Radiator cap
Well, that does make a lot of sense. The way you said it will be easy to remember... Thanks.
To How long for wait before opening hot radiator drain ?
