skip shift eliminator
Old Oct 26, 2014 | 11:59 PM
02ChrisC5's Avatar
02ChrisC5
Default skip shift eliminator
I ordered this from southern parts and want to put it on, where exactly is it located under the car? thanks for any help
Old Oct 27, 2014 | 08:00 AM
02ChrisC5's Avatar
02ChrisC5
Thank you very much, that is just what I needed.
Old Oct 27, 2014 | 09:00 AM
bjones7131's Avatar
bjones7131
I just installed mine two weeks ago, it is on the drivers side on the transmission.
Old Oct 27, 2014 | 10:01 AM
grantv's Avatar
grantv
The instructions that came with mine were very clear. Took me ~1/2 hour to build low profile ramps out of some wood I had, 3 minutes to back the car onto the ramps, and about 1 minute to install the thing. Great improvement. 1st to 4th, really?
Old Oct 29, 2014 | 09:48 AM
Brock63's Avatar
Brock63
can I assume that if I see the 1-4 skip shift indicator light but the car easily goes into 2nd without needing to go to 4th...that this has already been done?
Old Nov 2, 2014 | 01:45 PM
02ChrisC5's Avatar
02ChrisC5
Default cel
Ok, so I put it on and it works great, but everytime I start the car I get a check engine light. Code 0803 up shift solenoid, which I know has to do with the bypass. Did I hook something up wrong, this can't be normal. I clear the code and can drive without it coming back on until I start the car the next time.
Old Nov 2, 2014 | 02:51 PM
bjones7131's Avatar
bjones7131
Mine works as it should but i seldom get the light which is ok by me but a little unusual. Sometimes i get it sometimes i don't, go figure.
Old Nov 2, 2014 | 03:23 PM
02ChrisC5's Avatar
02ChrisC5
Thanks again! I took it back off and I hadn't snapped all the way together. I was just a little nervous because it was my first time under the car and it sits so low. It is now fixed.
Old Nov 5, 2014 | 09:14 AM
3boystoys's Avatar
3boystoys
Resistor is probably blown throwing that code, I think it uses a 220 ohm resistor, like 1/4 watt. When mine went I opened it up and replaced it with a 1 watt and it's been fine ever since.
Old Nov 5, 2014 | 04:05 PM
65GGvert's Avatar
65GGvert
Three days too late.
Old Nov 5, 2014 | 04:41 PM
bjones7131's Avatar
bjones7131
Is this resistor in the skip elim. device itself or somewhere else on the car, i would think it is in the device.
Old Nov 5, 2014 | 04:42 PM
3boystoys's Avatar
3boystoys
It's the entire device, that's all that's in it is a single resistor.
To skip shift eliminator
