Kudos to Vararam
Old Aug 1, 2002 | 07:07 PM
rfgoss1's Avatar
rfgoss1
Default Kudos to Vararam ttt
Just thought you ought to know that VR is a vendor dedicated to customer satisfaction. I was not thrilled with the perfromance of my car after the install of the VR, but I wasn't unhappy because I no longer have to worry about Hydro Lock. We got about 2 RWHP but lost about 3 RWTQ. RG at Exit 28 heard about it and notified Patrick at VR and Patrick called me at 8 pm that night to talk about the problem. He quickly determined that I needed more area from my filter and custom built a new one that he is overnighting to me at his expense!! He says that will solve my TQ problem. He also took the time to tell me about the extreme tests they did to challenge the possibility of Hydro Lock. I don't have time to print it all, but it was impressive. I am no longer worried when it rains. I will post the results after I install the new filter.
Randy Goss :cheers:
[Modified by rfgoss1, 5:08 PM 8/1/2002]
Old Aug 1, 2002 | 07:22 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Kudos to Vararam ttt (rfgoss1)
I am very happy to deal with a company like VaraRam. :cheers:
I'm glad you got to see one of the reasons why.:):)
RG
[Modified by RG in Dallas, 5:23 PM 8/1/2002]
Old Aug 1, 2002 | 08:00 PM
KorbenDallas's Avatar
KorbenDallas
Randy Goss :cheers:
Can you elaborate a little bit more about the hydro-lock testing they did and how the VR is worry-free? Inquiring minds would like to know!!!
Old Aug 1, 2002 | 08:14 PM
yelloz06's Avatar
yelloz06
Did you have one of the first generation air filters or the new style foam race filter?
Did you allow enough drive time for a re-learn?
Thanks :cheers:
Old Aug 1, 2002 | 08:28 PM
kewlbrz's Avatar
kewlbrz
lost about 3 RWTQ.
Will he be incorporating this modification into the next version of the vararam, or is this a one off adjustment for your heads/cam car that he will build and ship overnight on a case by case basis?
If possible, let us know the results when you get the modification done.
[Modified by kewlbrz, 6:33 PM 8/1/2002]
Old Aug 1, 2002 | 11:18 PM
rfgoss1's Avatar
rfgoss1
Default Re: Kudos to Vararam ttt (kewlbrz)
The Vararam is tunable. Talk to Patrick and he will explain. It has to do with things that I can't articulate. I am just not that technical.
Cheers
Randy Goss :cheers:
Old Aug 1, 2002 | 11:20 PM
rfgoss1's Avatar
rfgoss1
Default Re: Kudos to Vararam ttt (yelloz06)
I did allow enough time, but Patrick said I needed a more aggressive filter. This guy knows a lot about what makes power.
Randy :cheers:
Old Aug 1, 2002 | 11:24 PM
rfgoss1's Avatar
rfgoss1
Default Re: Kudos to Vararam ttt (FroDaddy)
Patrick said that they took two mules and really put them through a lot of wet situations. Ran it on the track in the rain, lots of different situations. Culminating with him taking a car and submerging the nose. No Hydrolock. He was emphatic about how hard it would be to hydrolock with this intake. Give him a call and he will elaborate I am sure.
Randy Goss :cheers:
Old Aug 2, 2002 | 10:44 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
rfgoss1- do you have the dyno graph on gains/loss from the VR? Were you running another intake before the VR? thanks,
Nate
Old Aug 2, 2002 | 03:39 PM
rfgoss1's Avatar
rfgoss1
Default Re: Kudos to Vararam ttt (Nate@xtreme)
Nate
I had the MTI True Ram Air. I will post the dyno sheets after I put the new filter in and run it again.
Randy Goss
To Kudos to Vararam
